Help me clutch problems
I have a 1999 honda civic ex vtec
d16y8 engine with 131k
the clutch wants to stall real bad when letting go and it grabs but what
can go wrong so it stalls like that
its completely stock no mods at all
so what can be the problem thanks so much
Re: Help me clutch problems
seriously come on the clutch i just got the car yesterday and would a ebay clutch be good thats 100 dollars
http://cgi.ebay.com/ebaymotors/92-05...item518e29a3cc
I hate the grind that these cars have when shifting into reverse. My 2001 Civic Si Coupe always grinds unless you are completely stopped and shift. If you are creeping in reverse even the slightest it will grind should you try to engage the gear. My BMW doesn't do that.
k i will adgust it but right now the oil leaks on engine oil
and i have oil pan gasket on the way and when thats done it will fix my clutch issues and yes i know how to drive a stick and for it to not stall i give it little gas and its fine but my other 04 chevy aveo clutch is fine i let go slowly and no bogging down engine but the honda almost all the way down bog and thats slow relaese
Hey, about tthat reverse gear; I am careful about stopping all the way b4 reverse gear, but it still grinds. I mean my car is a 00' Civic with like 140k miles. Will getting a new clutch solve the grind?
If it doesn't grind in any of the foreward gears, it doesn't sound like a clutch. Syncros maybe? I don't know enough about these 5 speeds to say, its just odd that you have to be completely stopped to shift into reverse.
Two externally cut gears. You need them both to go in reverse. But you have an issue because they are turning in another direction. That's where the idler gear comes in between them(2 gears turning clockwise. The idler gear turns CCW). If you get that in between these 2 gears, they rotate in the opposite direction(reverse). I THINK. I can't remember the entire process off the top of my head. That's why if the car is moving, you get that grind. I also don't think reverse is synchronized. Anybody wanna help me with this explanation?
I don't know about you guys, but hearing gears grind gives me the same facial expression as getting kicked in the *****
dinsum
May 28, 2015 09:30 PM
pantdino
15
May 13, 2015 02:22 PM
crowtoo
May 11, 2015 06:50 PM
CaptainAmerica
Feb 3, 2002 09:36 PM
Duh, I'm an idiot. Yes, see if it's adjusted right and check for leaks (usually happen at the slave cylinder or master cylinder).
