need help with my 2000 ex!!!!
Old Mar 21, 2010
2000ekex's Avatar
2000ekex is an unknown quantity at this point
car died while going down road one day, wouldnt start back, only thing we could get it to do was crank over. distributor was not putting spark to the plugs, so i pulled the cap and rotor button and replaced them, and still nothing. then replaced coil, and finally got spark car finally started and idled, but idles roughly now. doesnt miss while driving runs perfect while driving at constant speed. when i come to a stop light it idles down to about 400 rpms and tries to die if you turn the ac on it feels worse, and when the car is first started and motor is still cold it revs up slowly to 1800 rpms and varies from there. once it warms up it goes down to 1000 and varies from there. when you first start it up and motor is cold and it revs up slowly to 1800 if you rev it a little and let go of the throttle it goes back down to 900 rpms. could this be the iacv or the ditributor or what?? all input is thanked.
Old Mar 21, 2010
RaceNLive's Avatar
RaceNLive is an unknown quantity at this point
Re: need help with my 2000 ex!!!!
how many miles are on the car? I was having the same problem with my previous car which was a 2000 honda civic lx. I cleaned out the throttle body and IACV and pulled the F1 fuse to reset the idle and it worked. I followed this and it really helped. check it out and let me know if it works. https://www.civicforums.com/forums/7...e-up-mods.html
Old Mar 21, 2010
2000ekex's Avatar
it has 109000 on it. we replaced plugs cleaned the throttle body but not sure where the iacv is.
Crazygrlinak
Oct 8, 2015 05:06 PM
Le Ormz
Sep 30, 2015 09:24 AM
Hutch1051
Sep 29, 2015 09:20 AM
tropicola
Sep 25, 2015 07:02 PM
