No pressure in clutch pedal!
Old Mar 7, 2010
chrismac007's Avatar
chrismac007 is an unknown quantity at this point
About a week ago, it was very cold. My 1996 civic ex was sitting out during a freeze. A few days ago I jumped in the car and pressed the clutch only to find that there was no pressure whatsoever. After pumping the clutch for about a minute, I noticed that there was some pressure but not near enough to be working properly. I checked under the hood and found that there was some dried liquid below the clutch master cylinder. I'm not really sure what’s wrong or what to do first. I've read something about bleeding the clutch to remove any air. Could this be the only problem or am I most likely looking at a slave cylinder or master cylinder problem? Also, where is the bleeder valve? I’m not very knowledgeable when it comes to engines so any information would be greatly appreciated.
Thanks, Chris
Old Mar 8, 2010
89CRX's Avatar
89CRX is an unknown quantity at this point
Re: No pressure in clutch pedal!
sounds like u have a leak and it gets costly from there
Old Mar 8, 2010
02civicsi02's Avatar
Low and slow!
Ya you might have a leak some where. And the bleeder valve is toward the bottom of the fire wall somewhere. Just follow the cylinder down and you should see a little nipple and that should be it.
mrohitredd
40
Sep 9, 2017 12:03 PM
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
Kyles24
Jul 16, 2015 10:14 PM
Kyles24
Jul 12, 2015 09:15 PM
