Power window problems 1997 ek plz help!
Old Nov 28, 2008
97EXSweetSusie's Avatar
97EXSweetSusie is an unknown quantity at this point
ok i have a few problems goin on with my ek and i was hopeing someone out there could help. Ok first off for some reason the RH window wouldnt work so i thought it was the master switch goin bad so i replaced it and all was well and both windows worked then about a week and a half later the same thing happened where i could only role up and down the LH (drivers side). ANY IDEAS? (i thought maybe ampage of the RH window motor is fring the master switch or something idk?)
Second problem is that the LH window will not stay on track with all the bolts on there and tight it till pops off about half way any sugestions. (hasnt been in a acident so idk if maybe something is bend idk how?)
any help would be great thanks in Advanced Kyle
Old Nov 28, 2008
Re: Power window problems 1997 ek plz help!
open up the switch and see if you can spot any burnt residue. try and clean it up with alcohol and qtips. alot of times that will fix it.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
beveragemp
May 25, 2015 07:11 PM
got2kids
May 9, 2015 06:45 PM
bsmiley
Apr 27, 2015 01:27 PM
