Honda Civic NOT working??
Old Apr 20, 2008
nicokpe's Avatar
nicokpe is an unknown quantity at this point
I had a 1998 Honda Civic DX and discovered that my brake
lights are not working.
I began troubleshooting the problem by first replacing the brake light
switch (under the brake pedal) which didn't help and then replaced the
third brake light bulb (which was burn it out) but that didn't help too. Make me confuse.
After that I started looking at the brake light bulbs and discovered
something a little odd. The actual brake light bulb has two filaments
in it - the first is for the running lights and the second gets
illuminated when the brake pedal is pressed. What's happening with my
car is that if the headlights are on, both filaments are lit for some
unknown reason. Then I add that the turn signals still work so I
know that there is power in the circuit.
Any ideas to fix the problem?
Thanks
Old Apr 21, 2008
CraigW's Avatar
Re: Honda Civic NOT working??
Does the horn work ? (the brake lights and horn share a fuse)
A test light or a multimeter would help with troubleshooting problem.
Check the fuse and check for voltage present at the brake switch.
Old Apr 21, 2008
maybe the sockets got messed up or too much corrosion idk. since both light up together...
alexkharden
Apr 23, 2015 07:13 PM
jessicakaybby
Apr 20, 2015 12:11 PM
ashleymmackey
Apr 18, 2015 09:48 PM
dooner24
Apr 14, 2015 07:51 PM
