chinese android double din stereo from ebay wont fit
Rep Power: 0 chinese android double din stereo from ebay wont fit
Please help me anyone, i just got an android double din stereo from ebay which is china. It wont go through the double din dash kit because of the stereo being over sized. Any solution to this? Thanks and please reply
Rep Power: 183 Re: What did you do to your civic today?
You can make it work without a dash kit, I wouldn't though, because the dash kits fit tightly and look clean, it would be hard to recreate that. Plus they are cheap.
Rep Power: 131 Re: chinese android double din stereo from ebay wont fit
usually for double dins there's a bracket that screws into the side of the radio and then into the existing bracket. you have anything like that?
then you can get a trim ring like this to finish it off.
Rep Power: 0 Re: chinese android double din stereo from ebay wont fit
then you can get a trim ring like this to finish it off. Amazon.com: Scosche Dash Kit for 2001 - 2005 Honda Civic Double Din: Car Electronics
Last edited by xRiCeBoYx; 09-15-2015 at 07:36 AM. Reason: Personal info removed by admin
Received 1,148 Likes
Rep Power: 485 Re: chinese android double din stereo from ebay wont fit
I removed your email. Use the forum's PM system.
We just don't want you coming back years later asking us to remove your email address
Rep Power: 183 Re: chinese android double din stereo from ebay wont fit
I got the same thing as u sent me the link above the stereo is oversized and wont fit through it. So should i just install it without installing that kit or should i just return the stereo back ? I ordered this stereo from ebay and its a android double din. Please help me with this and wont the stereo look bad even if it fit without the dash kit? If any of u had done something like that please upload a pic or send it via PM. thanks!!!
Just a thought, make sure that it doesn't just fit very tightly, I write this because my stereo seemed like it wouldn't fit at first, but i just had to massage it in and it seemed to get stuck until I gave it a shove and it popped right in. can you post pics of where it doesn't clear or how tight the space is?
2001? Thread moved again.
robbie374
07-07-2015 02:56 AM
