DIY contest winner: Less Glare Head Unit Install (DIY)
Old Jun 13, 2005
LayinLo's Avatar
LayinLo is an unknown quantity at this point
There is not a good thread that contains all this info with pics, so I thought I'd save everyone some time and throw in some pics. Much props to Popcornplaya, cuz I followed his DIY really close with a few changes.
The pics are from my 2001 Ex, 5 speed, Coupe
For this install you'll need to get:
Metra parts #99-7865 (double DIN dash kit)
Metra parts # 88-00-9000 (universal pocket)
Tools:
screwdriver (phillips and flat)
5/16 socket (not necessary but helps)
Time:
15 minutes to 1 hour depending on experience
Step 1: Remove the cigarette lighter and fog light switch plate. I just stuck my thumb in and pulled out. Shouldn't be very hard.
Now unclip the wiring harnesses.
Step 2: Remove the two (2) screws holding the AC controls and Radio in the dash. This is where the 5/16 socket will help you to break the screw loose. After the first time these screws will come off with a screw driver very easily.
Step 3: Removing the AC controls and Radio
You can use a flat head screw driver to gently break the clips loose on your dash. Be careful not to gouge your dash.
Now unhook all the wiring harnesses from the back of the AC controls and Radio.
ID:	59857   Click image for larger version
ID:	59858   Click image for larger version
ID:	59859   Click image for larger version
ID:	59860   Click image for larger version
Old Jun 13, 2005
LayinLo's Avatar
Next take your whole AC unit and radio inside. Why work in the heat or cold when you can be comfortable inside, right?
Step 1: Take the ***** off the AC. They just pull right off.
Step 2: Unscrew the back of the AC controls. There are three screws.
Step 3: Mount your aftermarket radio in the bottom slot. I took the radio bracket off too. It has four (4) screws around the outside edges.
Most Pioneer, Alpine, and Eclipse mount right up to the side ISO holes. Screw it in tight.
ID:	59862   Click image for larger version
ID:	59863   Click image for larger version
ID:	59864   Click image for larger version
Old Jun 13, 2005
LayinLo's Avatar
Next we are going to mount the pocket. This is the Metra 88-00-9000 universal pocket. It comes with directions for Toyota, Nissan, Volvo, etc. but no Honda directions. I used the Toyota mounting brackets.
Step 1: Screw the bracket into the side of the pocket with the supplied screws.
Step 2: Now mount the pocket to the stock metal bracket (with supplied screws) where the radio used to be.
The pocket will only have 1 screw slot that fits. So, I took and screwed in the extra screws to give the pocket some stability. Now the pocket rests on the screw I just screwed in the side.
Step 3: Mount the stock bracket back up the the AC control and Radio panel from the dash. Wiggle it a little to get it back to the stock holes if the fitment is tight.
Step 4: Put it all back together in reverse order.
Remount your AC control with the three (3) screws you took off.
Put your ***** back on.
Go back outside and plug all the AC harnesses up and the radio harness.
Slide it all back into the dash.
Screw in the two (2) screws at the bottom of the AC/radio bracket.
Plug up the fog light and cigarette lighter plug.
Push the plate back on.
Go inside and show your mom/GF/friends how handy you are!!!
Now go enjoy a cold !!!!!
ID:	59866   Click image for larger version
ID:	59867   Click image for larger version
ID:	59868   Click image for larger version
Old Jun 13, 2005
PunkingCivic's Avatar
I need TP for my bunghole
set this to derek and have him add it to the diy section
Old Jun 13, 2005
LayinLo's Avatar
And the final product:
Old Jun 13, 2005
bluestreak's Avatar
bluestreak is an unknown quantity at this point
nice job, great DIY
Old Jun 13, 2005
PennyKnotOff's Avatar
Definitely gotta give this a try. Good job
Old Jun 13, 2005
I cannot find the part #: Metra parts #99-7865 (double DIN dash kit)
http://www.metraonline.com
Old Jun 13, 2005
S2KREY's Avatar
formerly 2k1CivicRacer
S2KREY is on a distinguished road
good diy... ill prolly try this later on in the week
Old Jun 13, 2005
AggressiveAdam's Avatar
AggressiveAdam will become famous soon enoughAggressiveAdam will become famous soon enough
I did this to my car, it does reduce the glare signifigantly and also makes the deck easier to reach.
Excellent mod.
Also if you have a pop out screen its farther away from the heating vents so thats a major +
Old Jun 13, 2005
TuRtLE714's Avatar
TuRtLE714 will become famous soon enoughTuRtLE714 will become famous soon enough
nioce! gonna do this when i get some free time
Old Jun 13, 2005
where do you get the kit.
Links please!
Old Jun 13, 2005
LayinLo's Avatar
Auto Toys
Try the link above.
Old Jun 13, 2005
thomusvoo's Avatar
Newbie Member
thomusvoo is on a distinguished road
nice nice
very useful
+1 rep for you
Old Jun 13, 2005
LayinLo's Avatar
'preciate it thomus!
Old Jun 13, 2005
BassKadett's Avatar
BassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to all
Man! This looks great, but I have the older one piece kit from way back in 01 and I don't feel like getting a new one. It has the slightly smaller pocket on the bottom.
Very well written! Thorough
Old Jun 13, 2005
auto84's Avatar
I R T3H 1338
auto84 will become famous soon enoughauto84 will become famous soon enough
Cool Man, Nice original idea!
Old Jun 13, 2005
XxSoVeReiGNxX's Avatar
BRILLIANT!!!!!!!!!!!!!!!!!! trying tomorrow morning
Old Sep 14, 2005
MegaHurtz's Avatar
stickified
Old Sep 19, 2005
spudracer326's Avatar
spudracer326 is an unknown quantity at this point
nice diy deffinitaly gonna do this soon.
Old Sep 19, 2005
20civic01's Avatar
20civic01 is an unknown quantity at this point
so if you have an 01 this won't work?
Old Sep 19, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
Yes it works in an 01. I did it wto years ago and wrote a DIY back then. Search for 0987654321234567890 and look for Radio Pocket flip flop DIY when it comes up as a result (I put a link in the contest thread). Pictures of it in an 01 are in there.
Old Oct 17, 2005
burke420's Avatar
The World Is Yours!
ooo i want. i hate my glare
Old Oct 24, 2005
02civic_rida's Avatar
+1 for you!
Old Nov 4, 2005
TuRtLE714's Avatar
can someone link for the double din pocket.
Old Dec 15, 2005
PiNoYxRaCeRxRH's Avatar
PiNoYxRaCeRxRH is an unknown quantity at this point
i was wondering if i can use this http://www.crutchfield.com/S-9hQHL6n...display=XL#Tab
instead of the toyota pocket kit?
Old Dec 31, 2005
AzNBonD's Avatar
AzNBonD is an unknown quantity at this point
Did this DIY even use the double DIN kit? It looks like he just mounted the tray and the cd deck on the factory brackets???
Old Jan 2, 2006
icewax_98's Avatar
icewax_98 is an unknown quantity at this point
Can anyone help me find this doubl din ?
thx
4 banger
Jun 5, 2015 01:44 AM
HondaHomer
May 14, 2015 12:24 PM
CivicVoz
Apr 16, 2015 08:07 PM
mugenca
Apr 16, 2015 12:15 AM
PimpBot5000
Nov 26, 2001 07:15 PM
