i would like an opinion of a set up like this is ok.
Old Jun 4, 2003
konstanting's Avatar
konstanting is an unknown quantity at this point
i wanna get a mono amp with 300watts (520watts max)
and put it together with a 200wattsRMS (400watts max) sub.
i dont know if the amp would blow the sub or what... i am just a noob so i dont know..
if anybody has a comment on this i would appriciate it. thanks.
Old Jun 4, 2003
LudlamTheory's Avatar
i boogie for the raindrops
what amp what sub everything
Old Jun 4, 2003
the sub is a....
JVC CS-LD3250
the amp is a .....
PowerAcoustik SPL2-520 2-Channel 520 Watts Amp
now if u tell me that this is crap, then please explain why cuz it will help me a lil .
some specs.......................................
;;;;;;;;;;;;;;;;;;;;;the sub;;;;;;;;;;;;;;;;;;;;;
Rec. Sealed Box Dims: not recommended
Rec. Ported Box Dims: not recommended
Free Air Usage: yes
Sensitivity: 92 dB
Frequency Response: 16-1500 Hz
Recommended RMS Power: 200W
Peak Power Handling: 400W
Impedance: 4 ohms
;;;;;;;;;;;;;;;;;;;;;the amp;;;;;;;;;;;;;;;;;;;;
Bridged Max Power: 520 Watts
RMS @ 4 Ohms: 125 x 2
RMS @ 2 Ohms: 150 x 2
RMS Mono: 300
Full Mosfet Power Supply
PWM Circuitry
Full Selectable Crossover Hi / Full / Low
Three Way Protection Circuit
2 Ohm Stable Stereo
Tri-Mode Capable
Variable Low Pass 40Hz-120Hz
Variable Hi Pass 150Hz-1.5Khz
18dB Bass Boost @ 40Hz.
Frequency Response: 10Hz to 30Khz
S/N Ratio: 97 db
THD: 0.02%
System Distress Indicator
High/Low Level Inputs / Floating Ground
4 Gauge Power/Ground Connection
Gold Plated RCA Connectors
Line Output
Dimensions: 11.25" x 2.25" x 11.25"
i hope that this helps out some thanks again.
Old Jun 4, 2003
first of all, that sub is reccomended for free air usage, not for a box. if youre going free air, go for that one. free air means youd mount it in the rear deck or the back seat and use the WHOLE trunk as your enclosure
Old Jun 5, 2003
yeah... i red that... dont like that i tried to just not read that line and try it anyways....but what about a sub with similar specs that goes in a box? would the amp and sub go along?
Old Jun 5, 2003
the next sub i was looking at was the...
Blaupunkt TSw1000
Rec. Sealed Box Dims: 0.30 - 1.00 cu.ft.
Rec. Ported Box Dims: 0.50 - 1.00 cu.ft.
Free Air Usage: yes
Sensitivity: 92 dB
Frequency Response: 20-200 Hz
Peak Power Handling: 600W
Impedance: 4 ohms
Old Jun 5, 2003
Ed's Avatar
Ed
What other subs were you considering, or, what is your price range? I'm sure others her can point you in the right direction. There's a lot of experience shoved into this forum
Old Jun 5, 2003
im looking for something around 100dollars, but my main thing is that it looks very clean ( the sub ) ....alot of the infinities are clean looking to me...but im not sure if they are a good choice.
Old Jun 5, 2003
i will actually get this sub"Pioneer TS-W2541C 10" Single Voice Coil Subwoofer" i can get it at a good price and i think its a pretty good one
Old Jun 5, 2003
Regularjoe's Avatar
Regularjoe is on a distinguished road
For $100 you should be able to get something better off ebay.
Not that the Pioneer isn't good, but you can do better for the same money.
http://cgi.ebay.com/ws/eBayISAPI.dll...category=39774
http://cgi.ebay.com/ws/eBayISAPI.dll...&category=3291
http://cgi.ebay.com/ws/eBayISAPI.dll...category=39771
http://cgi.ebay.com/ws/eBayISAPI.dll...category=18804
Old Jun 5, 2003
thanks for those links Regularjoe. the panasonic speaker i get for 60 bucks.. so i dont think thats a bad deal, unless someone can tell me why the speakers u linked to would be better over the once that i am looking at.
thanks for you help - konstanting
ttamrekab
Aug 23, 2015 07:45 PM
7thgensurvivor
Jul 27, 2015 08:23 PM
carid
Wheels and Tires
Jul 20, 2015 07:15 AM
jody501
Jul 10, 2015 11:01 AM
