2 stupid questions for Alpine CDA-9815 install !!!!!
Old May 30, 2003
Shadow's Avatar
Shadow is an unknown quantity at this point
Question 2 stupid questions for Alpine CDA-9815 install !!!!!
ok, finally got the HU i wanted...
am going to install it today after werk...
but was looking thru the manual and i have 2 stupid install questions...
1- i have the factory speakers (for now) and a bandpass sub box in the trunk, do i set the HU to 2-way mode or 3-way mode????
this is what the manual says: 2-way mode purs the highs in the front and rear and the lows in the sub, and 3-way mode puts the highs in the front, the mids in the rear, and the lows in the sub, but if you put it on 3-way mode you cant use the fader???
(reason i ask is cuz its a switch on the HU itself and i dont want to have to pull it out to change it lol)
2- i have my remote to the amp wired from the battery (fused ofcourse) and then to a switch by the emergency brake, then to the amp remote terminal. should i connect the remote lead to the radio to the switch, directly to the amp or just leave it the way it is so i can turn the amp on and off as i please?
THANKS IN ADVANCE FOR ALL YOUIR HELP, YOU GUYS HAVE SAVED ME SOOOOO MANY TIMES!!!!!!!!!
Old May 30, 2003
bzrollin's Avatar
bzrollin is an unknown quantity at this point
1 - set it to 2 way
2 - connect it to the radio's remote lead, there's no reason to be able to turn the amp on without the radio being on.
Old May 30, 2003
Shadow's Avatar
if i put it to 2 way wont it then only be playing highs throughout the car when the box is off? the reason i have the switch is because the box makes ridiculous bass and i dont always need/want the bass thumping my brain in my skull... so when i want to just listen to the music with the factory speakers i just hit the switch and the amp turns off...
Old May 30, 2003
Shadow's Avatar
what if i didnt have a sub? what would i connect it to then? i think thats my real question, cuz the amp is only on half the time... so i'd need to be able to have the HU play high mid and lows for when the amp is off...
Old May 30, 2003
bzrollin's Avatar
There is no need for that, thats what the subwoofer level control is for. and all the '2 way or 3way' thing is a built in crossover, if you dont want to use it, im sure there a way you can run your speakers full range. I would set it to 2way on the radio, then im sure there are ways to set turn the xovers on and off in the radio.
Old May 30, 2003
Shadow's Avatar
ok cool, thanks bro, i really appreciate it
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
danace99
23
Jun 28, 2015 08:49 AM
Crash2002
Jan 25, 2002 01:04 AM
trevor
Nov 16, 2001 05:02 PM
cazminn
Nov 9, 2001 11:18 AM
