Rear deck rattles
Old May 30, 2003
greggdogg's Avatar
greggdogg is an unknown quantity at this point
Rear deck rattles
I just had someone install rear speakers into my sedan. But the thing is now CONSTANTLY rattling. It even rattles when I go over bumps. I looked from the trunk up and there are 7 clips holding the deck in place. What can I do?
Old May 30, 2003
Bogus1's Avatar
Bogus1 is an unknown quantity at this point
I kind of have the same problem with my kickers, the deck rattles when i turn the radio up. I changed the rear speakers as well. Just make sure that the clips are not only attached to the car but to the rear deck as well. In my car they moved around loosly so when i was puttin it back some fell out of the rear deck. I'm thinking of redoing it, what i would do is use some 3M double sided tape and tape it down. Check which areas the rattle is comming from. If anyone has another suggestion let me hear it.
Old May 30, 2003
fonto's Avatar
The LA Clipper
I don't have any speakers in my rear deck, but this is what I did. I took a black t-shirt and tore it up. I made long 1/2 inch wide strips of 3 layers of the cloth and used a wooden ruler to stuff the shirt between the back window and dash (have to work around the back light). It works great, and I wish I would have used this method first before trying expanding foam on my back dash. Sometimes the cloth pops up, but it is hardly noticible because it is black, and it is super easy to stuff back in there.
Old May 30, 2003
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
Well I had a rattle and the only thing that I did to get rid of it was removed it, fatmatted it, and to this day no rattle has come from the deck. Now everything else in my car rattles. I bet that the people who did the install didn't realize that some of the clips didn't come out with the deck, rather they remained in the metal frame and when they put the deck back on, the clips didn't attach to the deck.
Old May 30, 2003
hyperhonda2k2's Avatar
Tempus Fugit
hyperhonda2k2 is an unknown quantity at this point
yea the same thing happens to mine, but i fixed it by replacing all the pop pieces and now it dosent do it.
Old May 30, 2003
JCap's Avatar
JCap is an unknown quantity at this point
I stuffed a couple erasers between the glass and the rear deck.... VOILA!
Old May 30, 2003
greggdogg's Avatar
Where on the rear deck? Between the brake light and the glass, or on the sides?
Old May 30, 2003
WhiteRabbit's Avatar
there are also more than clips that hold in teh rear deck, it actually slides into place as it approaches the glass, if those clips are resting on their places rather than in them, your deck could easily bounce up and hit teh glass, id double check that too.
oddtodd
Detailing
Aug 23, 2015 03:03 PM
loosescrew84
16
Aug 11, 2015 07:08 PM
frisbeeguy2
Jul 30, 2015 03:00 PM
Yazan93
Jul 14, 2015 08:56 PM
