Window Roll up Wiring
Old May 21, 2003
Dagooseisloose's Avatar
Dagooseisloose is an unknown quantity at this point
I have a Viper 300 alarm and I wanted to get the window automation system(viper 530T) is this easy to wire into an existing alarm? Any tips,tricks?
Old May 21, 2003
WhiteRabbit's Avatar
as far as i inderstand, it simply takes a pulse from a spare channel on the alarm, and rolls the windows down till it senses a load on the motors, stopping the windows.
should be pretty cut and dry, just window outputs, power, and trigger input. knowing DEI, that will translate into a wire harness of about 25 or so wires
but it shoudl seriously not bee to hard if yrou used to doing work on yrou car, readio installs, amplifier installs, shoudlnt be to hard at all.
Old May 21, 2003
tips are to equilize all yoru wire lengths just before you put the taps on, then tape them all up with electrical tape, it makes the job look more professional than to have a cluster of wiring down there.
i would reccommend cutting power and reconnecting it, rather than tapping power. it will make yrou power connection a little more reliable, and it wont be like you are cutting into the factory harnesses.
wherever you find the window wiring, id trace them till you found either the most convenient spot, or closest spot you can to the alarm brain, and tap there, to avoid having a spider web or wiring around yrou car.
and cleanliness is close to godliness! try to keep it clean! may not seem important, but when you service rou car, it becomes a huge issue....
Old May 21, 2003
AlpineCivic's Avatar
It's not to difficult but it just takes a little effort to get the wires in the door but othere than that few wires. White Rabbit is right tape your wires it not only looks better its easier to find your wires and it's less confusing, I put the same module in my car including one for my sunroof and it only took me about an hour but I am a professional installer if you've never done one it may take you a little longer.
Old May 29, 2003
luvvegas777's Avatar
banned from avatar useage
luvvegas777 is an unknown quantity at this point
if you need actual color code let me know
Old May 29, 2003
Color Code and Locations if possible would be nice.
Old May 30, 2003
i will get them to you by the end of sat, you're gonna need a 530 t which does 2 windows up and down. if you have an ex civic then you can get a 529t which does the sunroof.
you will need to run the wires into the door through the rubber boot, it's pretty easy, i just need to get into work and look up the colors and post for you
Old May 30, 2003
bzrollin's Avatar
bzrollin is an unknown quantity at this point
Wire codes are in this thread.
Old May 30, 2003
luv vegas, with that module also crack teh windows? or are you aware of any kit that will crack the windows?
Old May 30, 2003
bzrollin's Avatar
yes, the 530t will also crack the windows
Old May 30, 2003
so i could take 3 separate imputs and either roll the windows up roll them down OR crack them? ive got ALL three options with the single module? i must admit, i did not expect to have so much control with a single module....
or is it only 2 function, either up, either down, either crack, choose 2 of 3?
Old May 31, 2003
rolls up when you arm, cracks in increments, or hold down on your remote then they roll all the way down. must disarm then re-arm again to get them back up
Old May 31, 2003
will I be able to wire it so that i cna also hit a button on my remote, armed or dissarmed, to roll them all teh way up?
Old May 31, 2003
white rabbit: they roll up automatically when you arm them.
LF window up/dn: red/blk-red/yel all wires at window switch
RF window up/dn: blu/red-blu/wht
LR window up/dn: brn/wht-brown
RR window up/dn: blu/org-brn/yel
12v-white @ ignition harness
starter-black/white @ -ign harness
ignition black/yellow@ -ign harness
accessory-black/red @ign harness
pwr lock: white/ blue (-) polarity gray plug above driver's kick panel
pwr unlock: white/green
parking lights(+): red/black back of fuse box
trunk pin: red @ fac alarm plug-green plug above driver's kick panel
tachometer:blue @two pin plug to the passenger side of the battery
radio:
12v: wht/red
ground: black
accessory:yel/red
lf spk: grn/blk-lt green
rf spk: grn/yel-gray/red
lr spk:blu/wht-blu/blk
rr spkink-blu/yel
wipers: low----blue(-) polarity @steering column
high----blu/yel
Old Jun 1, 2003
that looks like our stock wiring diagram, not the diagram for teh 530T.....
Old Jun 1, 2003
bzrollin's Avatar
yes white rabbit, you would be able to make a button control up too if you wanted, the module uses a - pulse from the ground when armed on the alarm to close the windows, so a pulse from a channel would work as well. To open the windows you just need a validity channel, if you just press the button it will crack the windows, if you continue to hold the button for 3 sec. it will roll em all the way down. and dont forget about the one touch up AND down on BOTH windows, to get it from the passenger switch you will have to run 2 wires across the car though.
Old Jun 1, 2003
white rabbit the diagram will come with your 530t
Old Jun 1, 2003
BZ, i installed my own powerwindows, so i got that covered
thank you both, it was driving me crazy trying to sort out all teh modules available online, looking for one that would do what i wanted, this is it!
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
VBullon
Jul 2, 2015 09:24 PM
2HondaCivics
Jun 19, 2015 12:06 PM
timpan
May 18, 2015 07:06 AM
JDQuikCivic
Dec 4, 2001 04:22 PM
