infinity perfect 10
Old May 18, 2003
BlueTroll's Avatar
BlueTroll is an unknown quantity at this point
infinity perfect 10
i just bought a kappa perfect sub..... i wanna build a box for it.... BUT.... i was looking at the infinity specs.... and it doesn't give me any measurements..... just a volume figure.....
specs r here.....
infinity kappa perfect 10 specs
can someone tell me what measurements the box should be? thx.
pls help!
Old May 18, 2003
JohnDoe's Avatar
JohnDoe is an unknown quantity at this point
that box is only like .35 cubes of airspace... that sub wants .6 cubes.
make it around 12x12x8 and your sub will be happy
Old May 18, 2003
fonto's Avatar
The LA Clipper
You should use WinISD to build a box. It is a program that will give all of the info to achieve optimum performance for your subwoofer. All you have to do is input all of the specs for the sub, but I think that the Perfect may be already listed in WinISD, so you should have no problem. Maybe try porting it...I put ported ones in my girls car and they sound good, but check the specs because if you port it you can use more power according to Infinity's diagrams.
What ever you do, DO NOT buy a Q-logic box for the sub, because the perfect is a tad to small for a Q-logic 10" hole.
Old May 19, 2003
BlueTroll's Avatar
thx..... should i make the wall 3/4" or 1" thick???
by u mean 12x12x8...... do u mean that it not including the 3/4" or 1" thick wall?
hum.... i'll check out winISD i think i downloaded it b4.... but i didn't know how to use it..... i guess i'll get it again and play around wid it.... thx guys.
Old May 19, 2003
WhiteRabbit's Avatar
.75" is fine for that woofer.
and when they say .6 cubic feet, you can make it any size you want, jsut be sure that the INNER dimensions calculate .6 cubic feet
Old May 20, 2003
BlueTroll's Avatar
the .6 cubic feet..... do i hafta worry about the volume that the sub will take up?
i feel like a newb..... totally new to this sub building..... i am a newb to this.
when is says to tune the port to say 35Hz..... infinity gives me the specs of
length=10.4" & diameter=3.0"
how do i tune the port?....
thx.
Old May 20, 2003
JohnDoe's Avatar
don't mess with a port if you've never built a box. it's just one more thing to mess up and it changes the dimensions of the box. You should compensate for the space the sub takes up, but the dimensions I gave you should work fine because the total airspace for that box is actually about .67. You'll be happy with a sealed box for now. Then, if you feel more comfortable with it later try a ported box for it. You're only gonna spend about $20-$30 on the materials!
Old May 20, 2003
BlueTroll's Avatar
okies....... sounds good....... i'll just build a sealed box then...... thx.
Old May 20, 2003
fonto's Avatar
The LA Clipper
I just made my first box and I made it ported, and it wasn't that hard. I had some other problems that were more difficult and time consuming then adding ports.
I found all the materials I needed to make ports at Home Depot too...rember their moto "You can do it, we can help"
Old May 20, 2003
alex053's Avatar
i used to have 3 of those back in the day. they worked pretty good.
my advice:
blow your mine...........port your box.
Old May 21, 2003
BlueTroll's Avatar
hums....... my buddy is thinking of selling his 12w3 to me for 150CAN.... and the perfect 10 was also 150........
gotta go wid the JL man.
Old May 21, 2003
fonto's Avatar
The LA Clipper
I would go for the Perfect 10" IMO...I have owned them and liked them (infact they are in my girls car)...the only problem was a lil bit of tinsel slap.
Old May 21, 2003
OyD's Avatar
OyD
OyD is an unknown quantity at this point
i have 2 perfect 12.1's and they sound great. i also had JL subs a long time ago and from what i remember they were pretty kick *** too
Old May 21, 2003
BlueTroll's Avatar
i'm goin wid the JL 12w3...... i'd rather have a bigger sub.... 12" than have a 10"..... and i heard problems wid the perfects how their build quality ain't that great.
Old May 21, 2003
OyD's Avatar
OyD
that was with the first version of perfects
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Mad Dog Tannen
Oct 19, 2016 08:12 PM
rallyeredem0
Nov 2, 2015 10:56 PM
Munzy
21
Oct 7, 2015 07:48 AM
Wariogamer
Sep 29, 2015 09:49 AM
