Amp overheating...need help
Old May 17, 2003
justheman's Avatar
justheman is an unknown quantity at this point
I recently built a new amp rack... and it seems to lower the amount of air flow to my amps especially when my seats are up... I have seen them get up to about 113 degrees farenhit... I was wondering if it would work if I put fans in the back of it in my trunk blowing air to the back's of the amps... or do I need to have them facing a certain location on the amp... thanks for your time... and any Help.
-Justin
Old May 17, 2003
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
the best way to have the fan is oriented with the heatsinks, so it can channel the air over them and remove the heated air
Old May 17, 2003
JohnDoe's Avatar
JohnDoe is an unknown quantity at this point
How close are your seats to your amps? Also, did you pick a new grounding point for your amps when you built the rack, or lengthen your ground wire? If you're adding a cooling fan(s) the should be above your amp(s). Heat rises so put the fans where the heat is going.
Old May 18, 2003
tom1178's Avatar
tom1178 is an unknown quantity at this point
Are you using rear speakers? my friend has a 94 passat, he has a motorized amp rack that is just below where rear speakers would be mounted, he installed fans in the back deck to circulate cool air from the cabin of the car over the amps. this works very well for him because he is able to circulate cool cabin air to his amps instead of just blwoing more hot air from the already hot trunk over his amps
Old May 18, 2003
justheman's Avatar
well my heat sinks are pretty mcuh blocked off... and wne I have my seats up.. they are pretty mouch touching one another... the back of the seat and the heat sinks... thats I why I was wondering if I could put fans on the back or maybe the sides...
Old May 18, 2003
JohnDoe's Avatar
you might want to redo that amp rack, your amps will want at least an inch of air around them
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
wingsfan19
Oct 1, 2015 03:45 AM
Mc7602
Sep 17, 2015 02:01 PM
redcloud
Sep 7, 2015 01:45 PM
