How do i hook up my 4 channel amp with 2 subs?!?!
Old May 17, 2003
Rice's Avatar
Rice is an unknown quantity at this point
Ok i have a MTX 4244 (4 channel) amp
and 2 type S 12inch SVC subs
the amp is capable of bridging 4 channels into 2 channels @ 4ohms
at 120w X2
my question is.. how do i bridge them ?!
here's how the amp looks like:
for a better picture goto (http://www.mtxaudio.com/caraudio/archive/NDM184.pdf)
Front
right(+ - ) left(- +)
Rear
subs look like:
(+ -) (left sub)
(+ -) (right sub)
do i put the (+) terminal on one of the sub to the Front/Right (+) and (-) terminal on that sub to the Front/Left (-) ?
and then do i put the (+) terminal on the other sub to the Rear/Right (+) and (-) terminal on that sub to the Rear/Left (-) ?
Really need help !!
Old May 17, 2003
WhiteRabbit's Avatar
look at the amp, there should be a diagram that will tell you where to put the + and - terminals bridged. if not, check the owners manual, if you dont have it, check online fo rthe owners manual....
but you have ti right, each pair of channels will run a single subwoofer, bridged.
Old May 17, 2003
custom2k1's Avatar
custom2k1 is an unknown quantity at this point
There is only 1 thing you have to be concerned about when bridging that amp for subs. The rear channel is no problem but the front channels on the amp dont have a low pass crossover, so unless your deck has a crossover built in then you wont be able to run subs properly by using the 4 channel amp.
UltraHDGames
Jun 8, 2016 05:16 PM
Hutch1051
Sep 29, 2015 09:20 AM
Gsxtacy
Sep 12, 2015 01:09 AM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
redcloud
Sep 7, 2015 01:45 PM
