Wiring gurus? HID / headlight wiring harness.. wont work
Old May 16, 2003
MangoEX's Avatar
Just Be
MangoEX should not be trusted
I need help. Quite simply, i cannot get my full h4 (complete with relays etc) headlamp wiring harness to work with my H4 HID kit. I tried reversing the polarity of the plug that plugs into the car's OEM passenger side light socket (for activation via the headlamp stick in the cabin).... i know theres reverse polarity somewhere, where should I tweak the wiring? All i get is a click sound but no lights. So right now im using the car's oem light socket plugs which i dont wanna do toolong... too much voltage coming out of those ballasts
Old May 16, 2003
Hefe's Avatar
Second Place is the First Loser
Hefe is a jewel in the roughHefe is a jewel in the roughHefe is a jewel in the rough
What kit do you have? And post some pics.
Old May 16, 2003
pdxbiker's Avatar
pdxbiker is an unknown quantity at this point
Only the lowbeam lead off of your car's stock harness needs to be connected to the relay. You also have to suppy the ballastic with a full 12v from your battery. This is done by running 12v right from your battery to your relay. The lowbeam lead of your car's stock harness is used to trigger the relay to provide the full 12 v to your HID ballastic. You also have to run a ground wire from each harness to a ground in your engine compartment.
Some one please correct me if I'm wrong since its been awhile since I wired mine.
I believe Yellow Red is the low beam on your stock harness and Blue Red is your High beam.
Check your headlight fuse, I remember when I first hooked up my HIDs incorrectly I kept on blowing a fuse.
Old May 17, 2003
MangoEX's Avatar
Just Be
Hmm.. yeah i kinda thought of that theory, grounded everything properly, connected the harness to the battery... still nothing...i even played/reversed with the pins of all the sockets haha..
Old May 17, 2003
pdxbiker's Avatar
Hope this helps: http://faq.auto.light.tripod.com/headlamp-harness.html
Old Jul 2, 2003
luvvegas777's Avatar
banned from avatar useage
luvvegas777 is an unknown quantity at this point
if you have high and lo hid kit then there should be a diode wired inline with the wiring. you need to take it out and put it back in backwards.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
ORskier
May 3, 2015 12:54 PM
shaejb15
Apr 26, 2015 07:44 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
NukeSilo
Nov 4, 2001 09:37 PM
