Where to hook up amp ground in trunk?
Old May 9, 2003
eetfunk's Avatar
eetfunk is an unknown quantity at this point
Hi,
I just acquired a Honda Civic LX.
I will be installing my Pioneer radio and my Kenwood power amp very soon. I was just wondering where is the best place to plug the ground in the trunk. You guys are probably a lot more knowledgable than me since this is my first Honda.
Thanks!
Old May 9, 2003
bzrollin's Avatar
bzrollin is an unknown quantity at this point
i like to use the 'threshold' between the back seat and the trunk, because if you pull up the carpet, you can see that it is hollow underneath so you know you arent going to hit anything and the screw stays inside the car, so you dont put a hole to the outside that could eventually (looong term) cause some rust. Just use a self tapping screw.
Old May 9, 2003
LudlamTheory's Avatar
i boogie for the raindrops
anywhere thats metal will work =)
Old May 10, 2003
CiViCrAcEr2003's Avatar
CiViCrAcEr2003 is an unknown quantity at this point
make sure you get all the paint off your desired grounding point before you actually ground it...use a dremel or something like that to ensure the best connection.
Old May 10, 2003
clownprince's Avatar
Ricerus Maximus
I used the trunk latch on my sedan and I don't know what yours looks like or where you want to put the amp but that point has provided me with a very good grounding point.
Old May 12, 2003
Shadow's Avatar
Shadow is an unknown quantity at this point
i followed someone else's advice a few months back and used the bolt that holds down the rear seat belts...
should i change it to what bzrollin suggested or is that fine also?
Old May 12, 2003
Ed's Avatar
Ed
don't worry about it, anywhere that's metal is fine, if it sounds alright, keep it.
sbi
Sep 2, 2015 07:44 AM
jimmy23
Aug 31, 2015 10:35 PM
redcloud
Aug 26, 2015 11:27 AM
redcloud
25
Aug 12, 2015 01:23 PM
sch2cm
Jul 21, 2015 09:58 PM
