nutz
Old May 8, 2003
fonto's Avatar
The LA Clipper
nutz
What kinda of nuts or bolts should I use for my clamshell configuration? I normally just use some cheap wood screws, but I will need something strong enough to hold 2 subs to the box...I basically need something long and strong (get your mind outta the gutter )
I read something about t-bolts, but I have no idea what those are, and could not find them in the hardware store.
Old May 8, 2003
LudlamTheory's Avatar
i boogie for the raindrops
more commonly known as t-nuts, not t-bolts. you might be able to get away with just using long *** coarse drywall screws.
Old May 8, 2003
fonto's Avatar
The LA Clipper
ty
Old May 8, 2003
if youre having that much trouble, make the baffle (where the speaker is mounted) double thick, then use the super long coarse drywall screws so you have 1.5 inches of mdf holding the 8 screws as opposed to .75 inches
DriftR
Suspension DIY
30
Aug 16, 2016 11:57 PM
REDchirp
Florida
20
Jul 11, 2006 09:23 AM
REDchirp
15
Jul 6, 2006 05:37 PM
Forum Bot
Suspension DIY
May 17, 2004 07:14 PM
