FM reception need help
Old Apr 28, 2003
eyB's Avatar
eyB
eyB is an unknown quantity at this point
ok ever since i got my alpine deck ive really gotten crappy reception. i mean i still get the strong stations but the weak stations are totally static. i also have no AM reception since the AM antenna as i understand is located in the stock receiver, i dont mind at all since i dont listen to AM except when theres a game on. my question is do any of u guys know any device that could boost up my reception? i was thinking of this ONE wut u guys think?
Old Apr 28, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
wont do a damn thing. Alpines have notoriously bad radio reception. I have the same problems with mine.....your options are 1. new HU, 2. XM, 3. listen to CD's.
Old Apr 29, 2003
bzrollin's Avatar
bzrollin is an unknown quantity at this point
Huh, i dont really have any problems with my alpine's radio reception. Are you sure the power antenna lead is connected? Our cars do have an antenna booster in the car already that does require power.
Old Apr 29, 2003
Mystic3030's Avatar
It all depends on how far you are from the station. The local stations come in fine for me, but anything over say 40 miles is horrible....it came in fine with my stock radio. ANother thing that plays a part is if you ran power down the passenger side of the car.....it can interfere with the antenna cable.
Old May 1, 2003
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
I have great reception with my Alpine CDA-7893. This is what I think you should do. Check the antenna wire that plugs into the back of the HU and make sure it is in tightly. Also, that same antenna wire runs all the way through the dash and under the glove box. You may want to check to see if that connection is tight. It is right up under there by the kick panel right up under the glove box. Look for that black wire and make sure it is plugged in. I accidentaly pulled it out when I was installing my speakers, so just thought that could be causing your problem.
Old May 1, 2003
fonto's Avatar
The LA Clipper
I have had some problems with reception...some tips that I have learned:
-if you are using a device that runs near the HU, like the defroster, this can cloud reception (actually the back window defroster may cause bad reception because it is on the back window with the antenna).
-Driving on a crowded freeway, like the 405, can cause bad reception with big trucks nearby.
-Make sure the radio antenna is connected at all points: behind radio, in kick, and at back window.
Just some ideas
ChrisHandHonda
26
Sep 25, 2015 11:28 PM
scottf
Dec 2, 2002 08:08 AM
scottf
Nov 29, 2002 11:21 PM
IDriveANissan
Aug 9, 2002 11:07 PM
