Results of dynamat install
Old Apr 24, 2003
Well, I finally got the time to take my car apart and put some dynamat around. So far I have all four doors done (sedan), the rear deck, and trunk. Unfortunately, I didn't get the results I was looking for. It didn't help road noise at all. It did increase the quality of sound from the speakers, although the sub level seems to have dropped. I was fooled by the ads that say this product reduces road noise.
Dynamat actually lowers vibration and panel resonance, NOT road noise. When I do the floor, I'll probably use a little dynamat and also some V-comp absorbing foam. Just wanted to let you know my experience.
Old Apr 24, 2003
cdmx's Avatar
thanks for the info....dynamat is just some heavier stuff i dont need in my car...but still good to know what you think of your install
Old Apr 24, 2003
CivicBR900EX's Avatar
Master
CivicBR900EX is an unknown quantity at this point
quiet heavy and expensive.
Old Apr 24, 2003
RSXtypeIvtec's Avatar
Su Mo
i agree
Old Apr 24, 2003
SQCivic's Avatar
SQCivic is an unknown quantity at this point
Dynamt does an excellent job if applied correctly. It will reduce road noise somewhat but it is not designed for that purpose. Like you mentioned it is a damping mat to reduce resonance. TacMat or something similar in conjunction with the Dynamat will actually help reduce road noise. How many layers did you put on the doors and floors?
Old Apr 24, 2003
Subrage's Avatar
Subrage is an unknown quantity at this point
i put a layer of rammatt down, it helped with both road noise and viberations. I would suggest another layer in the doors. I put it both on the outer shell of the door and the inner one. i still wanna do another layer on them and the floor
Old Apr 24, 2003
Frank2sy's Avatar
Frank2sy is an unknown quantity at this point
So what will help with road noise?
Old Apr 24, 2003
ImPulse's Avatar
Old Apr 24, 2003
mohawkboom's Avatar
dynamat regular is only 40 mils thick...it's not the greatest deadener in 1 layer. and it's a little thin..
Raam Mat, fatmat and brown bread are all 60 mils think and aluminum backed which helps a little more with road noise and deadens noticably better than dynamat regular. and it's even cheaper ..
Old Apr 25, 2003
I'm thinking about doing the floors with vcomp for road noise. Hope this helps. And I only did one layer of extreme dynamat on the doors, rear deck, and trunk.--no noticable difference.
Old Jul 17, 2003
orion_squall's Avatar
hi,
what kind of gule you guys use to glue back the factory white sheet back on the dool panel?
for fatmat, we need to first remove the factory white sheet on door panel, then apply fatmat on door panel, but then, how do I glue back the white sheet? what kind of glue do I use?
thanks
Old Jul 17, 2003
LudlamTheory's Avatar
i boogie for the raindrops
i ripped my plastic sheet off... you could use any glues, hot glue gun would work quite well...
Old Jul 18, 2003
alex053's Avatar
who needs a plastic sheet when you fill that entire space with expanding foam. I also used RF Noise Killer Mat on my trunk lid. Three 10s with 1500 watts and barely a rattle.
Old Jul 18, 2003
The plastic sheet is worthless and probably makes more noise. Just throw it away and put some v-comp over the fatmat.
Old Jul 19, 2003
EnProceso's Avatar
IMO dynamat and fatmat are worthless for improving sound or killing road noise, only good for stopping rattles.
Old Jul 20, 2003
Actually, dynamat did help noticably with speaker panel distortion. It made the speakers sound cleaner and louder. It is not a sound absorbing mat and won't help with road noise unless you add a lot of layers.
mjdiaz89
Jun 21, 2016 09:26 PM
carid
Nov 7, 2015 01:46 AM
Misfit2613
Jul 30, 2015 09:49 AM
Jul 12, 2015 11:54 AM
user 84948
Air Conditioning
40
Jul 10, 2015 07:08 PM
