static in speakers
Old Apr 22, 2003
Cypher's Avatar
Cypher is an unknown quantity at this point
Question static in speakers
i have a 4 ch amp for my cabin speakers and for some reason there has been off and on static coming from the speakers...it comes and goes..sometimes its loud sometimes its soft...is it a bad ground or could it be from RCA's being close to the power wire (rca's moving around) ? I'm thinking its from RCA's being to close...but this only started happen recently....Could it also be that i have blown speakers or speakers playing bass when their not suppose to be...i've been playing with my settings and everything is set on highs and it still does it..
Old Apr 23, 2003
LudlamTheory's Avatar
i boogie for the raindrops
does the sound of the static change the more you rev?
Old Apr 23, 2003
Cypher's Avatar
nope its constant...it goes on and off...sometimes i hear it sometimes its gone....today i dont think i herd it....could it also be because of a defective amp ? i dont know...
Old Apr 24, 2003
mohawkboom's Avatar
okay if it gets louder and softer it's most likely being caused by your A/C switch wire under the dash..did you run the RCA's down the drivers side of the car.?
Old Apr 24, 2003
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
I had a problem similar to that, but it had to do with the alternator. When I accelerated, the noise got louer, and vis versa when I slowed down. I went to radio shack and they have me somehthing that I basically connnected to the RCA cable and it filtered the noise out. You should give it a try. It isn't expensive and you can always return it to radio shack if it doesn't work. I don't know the specific name, but tell them the problem and they should point it out to you. Since you have a 4 channel amp, just connect this to the RCA cables that carry the signal for those speakers that are making the noise, rear or front speakers. If you have anymore questions, just PM me or something.
Mad Dog Tannen
Oct 19, 2016 08:12 PM
UltraHDGames
Jun 8, 2016 05:16 PM
meicalnissyen
Sep 25, 2015 12:12 AM
Gsxtacy
Sep 12, 2015 01:09 AM
redcloud
Sep 7, 2015 01:45 PM
