Another, What subs should go with this Amp Question??
Old Apr 15, 2003
cruciatus's Avatar
cruciatus is an unknown quantity at this point
Arrow Another, What subs should go with this Amp Question??
I have a friend that has an amp I am prob gonna buy from him. It is a JL Audio 500/1. I have been out of the seen for a while, not sure if this is a good amp or not. But i could prob get it pretty cheap (under 300).
People with knowledge of this amp, what kind of speakers should i be looking at?
2 Ohm,, 4 Ohm,,, DVC? I like the MTX 8000 or the JL line, or the Fosgate line. What is the most powerful speaker i can put in their that this amp would do well with?
also, (newb question),, if i was to go buy an LCD screen, is their anything special to look for? I would like to just get an LCD ,, and put in my PS2 to play the DVD's. Anything special about that? is it,, wire from the radio, to the lcd, then to the PS2?
thanks
Old Apr 15, 2003
Ed's Avatar
Ed
That JL amp is a great unit, it's 500 watts rms from 1.5 to 4 ohms. You can hook up just about any sub for 500 watts.
For the subs, you should go get whatever sounds good to you. Do you plan on having 1 or more subs?
I'd connect the LCD directly to the PS2, then you can connect the PS2 to the Auxiliary input, or you can get an FM modulator if you really want (it won't sound as good). I think as long as the LCD has RCA inputs, you'll be fine.
Old Apr 15, 2003
cruciatus's Avatar
well,, i either want to go with one bad **** sub,,, or 2 semi bad **** subs. or whatever is better,, one or 2 speakers with this amp..I like the Fosgate and the JL line. Since i have been out of it for a while ,, i dont know what is better as in sound and what kind of wattage i should be looking at for this amp. I want some friggin bass!
Old Apr 15, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
I would go with either two W3v2's, one W6v2, one Eclipse Aluminum, two Diamond M3's or one Diamond M6.......those are some options to look into. Another popular choice on here are Adire Audio products, I havent actually heard them though, so I can't make a recomendation. IDQ also comes highly recomended, but again, I have no personal experience with them
Old Apr 16, 2003
cruciatus's Avatar
so,, would this setup (amp 500/1) sound better pushing one 12w6v2,,, one 10 or 12w7,,,, or two 12w3v2's? I wouldnt mind going with only one speaker. but i want it to be a powerful one. Would i see a big diff from say two 12w3v2's and one 12w6v2 or a 12w7? If not i would rather just go with one powerful speaker.....thanks
Old Apr 16, 2003
LudlamTheory's Avatar
i boogie for the raindrops
thats not enough power for a w7 of any size
Old Apr 16, 2003
Mystic3030's Avatar
It's enough for a 10, the 10 asks for 500 WRMS You would be better off with a 12W6 though....same SQ as the 12W7, but slightly less SPL for half the price.
Old Apr 16, 2003
12w7 is rated at 750 but JL reccomends 1000, those w7's do WELL in high powered situations. warranty on 13.5 isnt even voided unless you break 2 kw
Old Apr 16, 2003
now that i remember, WR installed a 10w7 with about 4 or 500 watts i think. i believe he wanted more power
Old Apr 16, 2003
Mystic3030's Avatar
Yeah, that was what I forgot to mention....the 12W6 only needs 400 watts I think....versus the 1000 that the W7 needs. And yes, the 10W7 is rated at 500, it runs decently at 500, but it needs about 800 to really shine.
Old Apr 16, 2003
cruciatus's Avatar
so one 12w6v2 or 2? or are you referring to a regular 12w6? one or two
Old Apr 17, 2003
single 12w6v2 would be nice
Old Apr 17, 2003
cruciatus's Avatar
sorry for my ignorance,,,,,, but which would sound better,, sq, spl, and bass wise,,, one of the 12w6v2 or 2 12w3v2's? thanks
Old Apr 17, 2003
BlessedAggie's Avatar
BlessedAggie is an unknown quantity at this point
10w7
Old Apr 17, 2003
Mystic3030's Avatar
THey have very similar sound, however for your application, the W6v2 will play louder because of the power you have. A 10W7 needs about 800 watts to really shine and play to it's full potential, whereas a 12W6v2 will be perfectly matched with your 500/1. Now if you had 1000 watts to play with, thats a whole different story.
Old Apr 17, 2003
WhiteRabbit's Avatar
since you are looking for loud, (according to the first post) I would eiter go with a pair of 12w3v2's or a pair of 15w0's.
that will maximize your bass/dollar ratio with that amplifier. chances are, you wont hear the difference between any of them assuming you give them all the proper install.
redcloud
25
Aug 12, 2015 01:23 PM
mrwhos
Aug 11, 2015 02:03 AM
Civic65
Jul 19, 2015 10:13 AM
phantommaggot
Engine start problems
Jul 12, 2015 12:55 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
