Subs for Friend
Old Apr 10, 2003
PopcornPlaya's Avatar
Electric Boogaloo...
Subs for Friend
alright, a friend of mine has a 94' Z-71 extended cab, and is going to be putting in some 10 in. sub(s). he is really wanting to use q-logic thunderforms or some type of custom enclosure under the rear seat. i told him i could build him a box that'd fit, but he said he really wants the stock apperance of the thunderform. i told him i could get the carpet and all that's match up to the factory color. hell, i have built tons of boxes, and he wouldn't know it wasn't factory. i am thinking that he is going to waste money on the thunderform anyway, but i really dont care cause its his money. anyway, if he goes this way, he'll have about 0.65 cubes per woofer, and i was wondering if any of you could suggest some subs that'd be loud and have good sq at the same time. he really wants it to pound, but i am going to make sure that it isn't that ghetto boom. also, he probably wont spend much more than about $175 per speaker. i was thinking something like a JL 10W0 or a W3. but if you know of something that'd be better for this install, then i am open to your suggestions. he may not spend that much on them. anyway, if you know of some good subs for cheaper that'd be fine as well. thanks in advance.
Old Apr 11, 2003
LudlamTheory's Avatar
i boogie for the raindrops
image dynamics IDQ 10 would work, or an eclipse alum 10 might. I know the alum 12 runs in around .75 or .8 cf perm so therefore the 10 will prolly go good there. audiomobile mass 10 could work. Theres lotsa small box woofers out there. what amp does he have to power them?
Old Apr 11, 2003
no amp yet... i will be looking for the amp once he decides on the subs... so i'm open on that as well... if you want you can suggest both, so i dont have to ask later...its going to be a new install, so everything has to be bought... should i tell him to let me build him a dual 10 box with either shared cubic volume, or one with seperate cubic volume to go in there? i am confident that i could do either cause i have built a bunch of boxes before...or should i let him waste his money on the thunderforms?
Old Apr 12, 2003
CivicEnvy2001's Avatar
CivicEnvy2001 is an unknown quantity at this point
I'd go with eclipse.
Old Apr 14, 2003
alright, i have convinced him to let me build the enclosure, and i have a question, before i undertake it... being that this is going under the rear seat, i was wondering what type of enclosure to build? the way i have it figured, i can get around .65 to .70 cubes out of it, unless he says that i can remove the jack and place it in his tool box, which i could probably get double out of it then, or possibly make it a dual box. but, if i cannot remove the jack, should i make it a closed box, or port it? i have figured it up both ways, and diagramed it each way, but i dont know which would be better/louder. we havent decided on the sub or amp yet, either, which also would have a great deal of bearing on which to do i am guessing. i think what were gonna do it make it a single sub box, and use the area where the jack is to mount the amp(s), cap, line driver, crossovers, whatever he wants located there... but mainly, i was wondering which type of bow to build... i am going to leave about an inch or so between the seat, and the top of the box, that way i can be assured that if i build a ported enclosure, it will still be able to suck air. but if it should be enclosed, then i can go to almost the bottom of the seat. of course, i will probably still leave the 1 inch or so, because it is looking like i am goint to have to either drop the sub in from the top or come in from the bottom, because of the height restrictions. any suggestions? it is only about a little less than 8 inches in height. i haven't looked at the thunder form to see which way the sub is mounted in it, but i am fairly certain that it is in the same fashion... suggestions please...
Old Apr 14, 2003
o, and i almost forgot, i will be putting a grille over the sub because of the way i will probably have to put it in the box. i knew that from teh get go, so that will save on the "make sure you put a grille on it" posts...
Old Apr 14, 2003
with that little airspace, youd have to go sealed.
UltraHDGames
Jun 8, 2016 05:16 PM
ken4444
Sep 30, 2015 07:37 PM
carid
Sep 28, 2015 10:13 AM
Mc7602
Sep 17, 2015 02:01 PM
redcloud
Sep 7, 2015 01:45 PM
