need sum help with subs and amps
Old Apr 7, 2003
dKj's Avatar
dKj
dKj is an unknown quantity at this point
im getting a new setup for my car, and i was reading sum threads and it just got me more confused.
first, wut duz it mean if the specs for a sub says 4 ohms + 4 ohms? i think its sumthin about dual voice coil, but i have no idea wut that means. duz it affect at all how much power i need to power the subs with?
also, for amps that are bridgable into one channel for more power, are there any changes i have to do to my setup to accomodate this? and are there any disadvantages to bridging an amp?
Old Apr 17, 2003
tbone323's Avatar
tbone323 is an unknown quantity at this point
dual voice coils mean that there are 2 sets of inputs on the speaker...this is usually done so that you can customze the impedance of the driver to fit your system. If you wire 2 -4OHMS in parallel, you get a 2-OHM load, if you do them in series you get an 8-OHM load. Or, you could run each coil independantly like 2 amps per sub (but make sure you have identical amps and subs that can handle that!!)
As for bridgeing, esentially, it sums the power form 2 channels to one so that you get twice the power for 1 speaker. It doesn't require anything special to be done to the amp besides rewiring the output acording to the instruction manual. This is kinda an old thread so i dunno if you're still following it or if you even care anymore, but if you are and have more ?'s, feel free to ask.
~Tbone
GolNat
Nov 27, 2018 03:32 PM
UltraHDGames
Jun 8, 2016 05:16 PM
General DIY
Sep 25, 2015 08:02 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
redcloud
Sep 7, 2015 01:45 PM
