Noob to Subs
Old Mar 31, 2003
GideoN's Avatar
GideoN is an unknown quantity at this point
Noob to Subs
Sorry guys, I have searched to see if anyone has posted plan, actual measurements to build enclosures but the only one I have seen was in the DIY section. I have seen a poster before of many different enclosures with measurements. Do any of you have plans for enclosures? I am wanting to try to build one. Thanks!
Old Mar 31, 2003
WhiteRabbit's Avatar
theres nothing to it, a simple cubic enclosure, you multiply teh inside dimensions toghether, lxwxh in inches and divide by 1728. that gives you the internal airspace, which you match up reasonably close to what is needed by teh subwoofer. to go backwards, you know the airspace you need, so you multiply the space by 1728 and divide by 2 of teh dimensions youve decided on to figure out the third. then you have yoru dimensions.
from there its jsut a matter of figuring out which pieces will be bigger than the the others to get a cubic box to fit, thats easy enough, there is no rule, just go for it., it wont affect performance of a well built box.
as to specifics minus design, the DIY box is good enough, just go for it!
GolNat
Nov 27, 2018 03:32 PM
UltraHDGames
Jun 8, 2016 05:16 PM
General DIY
Sep 25, 2015 08:02 PM
sf3r8z
Sep 23, 2015 03:26 PM
redcloud
Sep 7, 2015 01:45 PM
