help static with radio
Old Mar 30, 2003
sandgrencivic's Avatar
sandgrencivic is an unknown quantity at this point
Question help static with radio
I am having a big problem with my radio. I installed 2 kicker solobarics, with a phoenix gold 1200.1 amp. the amp is mounted to the back of the rear seat, and the box is in the trunk. If I turn the circuit breaker off, so my amp is not running then I get all my stations really clear. As soon as I turn on my amp, it all goes static. Does anyone know what I can do? I hate not having a radio. Thanks guys.
Old Mar 30, 2003
LudlamTheory's Avatar
i boogie for the raindrops
the power wire is interfering with your antenna cable
Old Mar 30, 2003
fonto's Avatar
The LA Clipper
is the power wire not supposed to be run next to the power cable?
Old Mar 30, 2003
what was that fonto?
Old Mar 30, 2003
fonto's Avatar
The LA Clipper
I am just wondering if I should not have my power wire running next to my antenna wire?
I said power twice instead of antenna wire
Old Mar 30, 2003
fonto, sometimes if its at a retarded angle it causes interference in the reception. I wouldn't know since i don't even have the presets on my radio set yet.
Old Mar 30, 2003
I understand that, but how should I go about fixing the problem. What are some suggestions, do I need to move my amp or what??
Old Mar 31, 2003
DizWikedCivic's Avatar
i think it does, cuz my power cable is next to my antenna cable, and my radio reception is hella wack, before i never had this problem
Old Mar 31, 2003
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
when i first installed my headunit, the reception sucked, but then i connected the power antenna wire up to the switched 12 volt wire on the headunit's harness, now the reception is much better, not as good as the oem hu's reception.
Old Apr 3, 2003
I need some suggestions of how to fix the problem. Anyone, just let me know, cause I want to leave the amp in that position.
Old Apr 3, 2003
im thinking the power cable is interfering with the reception cuz my receptions is wack too
Old Apr 3, 2003
killah99si's Avatar
killah99si is an unknown quantity at this point
That is real strange? I've done plenty of amp installs on 2k1 and up civic without any problems? where exactly is the amp mounted?
Old Apr 3, 2003
The amp is mounted to the back of the back seat. It is on the larger fold down seat, mounted to the back. And my subs are in the trunk as well backed up close to the amp.
Old Apr 4, 2003
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
Sounds like your RCA cables. Tell me if this sounds like the problem that I had. After I installed my second amplifier for my speakers, everytime I turn on my car, there was an alternator whine. It increases and decreases depending on your cars RPM. When my car was only on accessory though, this was not a problem. Does this sound like the problem? Either that or you somehow don't have a good antenna connection. Check in on the back of the HU, and also on the passenger side right up under the dash, there is the black antenna wire. It plugs in right up under there, I know since I accidentally pulled mine out a few times. That may not be plugged in all the way or something like that. If you have any questions, PM me and I may be able to help more.
Old Apr 4, 2003
The thing is, is when I cut the power to my amp, then the radio is completely fine. So I don't think it is a bad connection. And I doubt it is the cables, because it doesnt depend on the rpm, and I dont hear a whine from the alternator.
ricer_em2
May 11, 2016 08:09 PM
thebmillz
Electronics
Oct 2, 2015 08:38 PM
Mc7602
Sep 17, 2015 02:01 PM
jpat21
Sep 3, 2015 11:32 PM
