Is Bridging this amp possible?
Old Mar 23, 2003
PopcornPlaya's Avatar
Electric Boogaloo...
i was told that bridging my JL Audio Monoblock 500/1 was not possible by first the audio shop i bought it at and then by a couple more people, i am wondering if this is true? i haven't tried it yet, but it seems that it would be bridgable. if so, what would my watts jump to roughly? my speaker can handle up to 1500, and they told me if i blowed it they would give me another and a second for free, as long as i use the rated wattage for it, and nothing over that. i was not going to attempt it, but i was curious when they said this bout the amp.
Old Mar 23, 2003
dups's Avatar
dups is an unknown quantity at this point
Somebody correct me if I'm wrong, but I believe you have a 1 channel mono amp. you can't bridge 1 channel. When you bridge you connect the power from multiple channels to create one big output. But like I said, I might be wrong. But your amp has only 1 left and 1 right channel and they put out the power advertised.
Old Mar 23, 2003
LudlamTheory's Avatar
i boogie for the raindrops
no, it doesnt have one left and 1 right, only a single positive and a single negative... plus the fact that your JL runs the same power between 1.5 and 4 ohms
Old Mar 23, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
It's a monobloc amp...1 channel. It may look bridgeable to you because there are 2 positive and 2 negative terminals for your subs....but thats for if you had one of those boxes where there are two terminals for 2 subs.
Old Mar 28, 2003
dups's Avatar
thats what I meant, a positive and a negative.... opps.
Old Mar 29, 2003
JohnDoe's Avatar
JohnDoe is an unknown quantity at this point
it's not possible to bridge a monoblock amp. Your power will not go up. Do not pass go. Do not collect $200.
Old Apr 2, 2003
custom2k1's Avatar
custom2k1 is an unknown quantity at this point
The whole concept of the mono block amp is that its already bridged internally. You send it left and right channels and the output is a mono signal. If you take apart most monoblock amps you will see that both positives connect together on the board and both negatives connect together on the board. It doesnt matter what combination of + and - you use, it all goes to the same place.
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
curaze
Sep 22, 2015 08:27 AM
Mc7602
Sep 17, 2015 02:01 PM
redcloud
Sep 7, 2015 01:45 PM
