2,4,8volts?
Old Mar 9, 2003
aldini's Avatar
aldini is an unknown quantity at this point
2,4,8volts?
Head Units:
Some units have 2 volts, other units have 4 volts, some eclipses even go as far as 8, or 16 volts... Will i be able to tell the difference on these? Is it worth the extra money? (Not for the 16 volts, but the difference between 4 to 8 volts???)
I'm trying to decide between the new Alpine 9807 (3 sets of 4 volt)
Or an Eclipse (Don't know the model) with 3 sets of 8 volts.
Price difference is about $50
Old Mar 10, 2003
DizWikedCivic's Avatar
well some say the higher the voltage the more cleaner your music is, and some say if your gain is set correctly it wont matter
Old Mar 10, 2003
LudlamTheory's Avatar
i boogie for the raindrops
8 volts would usually leave you with a cleaner signal, but lotsa times your amps can't handle 8 volts. 4 is more than youll ever need for a daily driver
Old Mar 10, 2003
alex053's Avatar
has to do with signal to noise ratio. If you have higher signal voltage then your noise floor will be lower. 4V is good enuff for 90% of the people out there.
Old Mar 10, 2003
izod's Avatar
izod is an unknown quantity at this point
I've got 8 volt pre-outs. My jl 300/4 has to be turned down on sensitivity, but the 1000/1 eats it up [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Mar 10, 2003
aldini's Avatar
so how do you know what your amp can take? I have a JBL P80.4 and an MTX2150x??
Old Mar 10, 2003
Cyko's Avatar
Cyko is an unknown quantity at this point
yer amp should have the stats somewhere on what it takes [IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
Old Mar 10, 2003
aldini's Avatar
I found my 2150x ok, but the JBL P80.4 is not listed anywhere on the website either.. it's probably 4 volts huh?
alex053
Jun 30, 2004 12:00 AM
