Good place to ground amp.
Old Mar 9, 2003
2k3silver's Avatar
2k3silver is an unknown quantity at this point
What is a good way to ground my amp in the trunk?
nut and bolt??? do i need to drill?
thanks.
Old Mar 9, 2003
DizWikedCivic's Avatar
you can try the selt belt bolt, spare tire bolt or just drill a hole
Old Mar 9, 2003
666's Avatar
666
666 is an unknown quantity at this point
Use a self tapping screw but make sure to sand or srape off the paint were the ground screw goes to make a good connection.
Old Mar 9, 2003
jefff's Avatar
jefff is an unknown quantity at this point
make sure you paint over the hole from BOTH sides after the connection is made so that it doesn't rust too![IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Mar 9, 2003
2k3silver's Avatar
seatbelt bolt??
will that be hidden?
is that an easy way?
and what is a self tapping screw?
Old Mar 10, 2003
seat belt bolt is under the rear seat
Old Mar 10, 2003
2k3silver's Avatar
IS it ok for the seat to tuch the ground?
Old Mar 10, 2003
Quote
[hr]Originally posted by: 2k3silver
IS it ok for the seat to tuch the ground?[hr]
where are u mounting your amp at? try to keep your ground short as possiblem, no more than 3ft
Old Mar 10, 2003
ce01cvcex's Avatar
ce01cvcex is an unknown quantity at this point
Quote
[hr]and what is a self tapping screw?[hr]
a self tapping screw is a screw for metal with a drill bit type end on it, it bores the hole, then the threeads run in, it basically has a pilot bit in front of the threads, lowes, home depot, etc. wil have them, just tell them you need some self-tapping screws, and they will show you a sheiot load of different ones.
SoyerOner
May 11, 2015 09:46 PM
LikeWh0a
Nov 27, 2001 04:24 PM
wawacito
Nov 5, 2001 03:32 PM
ChiFroBoy
Oct 24, 2001 01:32 AM
wsking77
Aug 30, 2001 12:32 PM
