For those that mounted spare tire under car
Old Mar 8, 2003
tom1178's Avatar
tom1178 is an unknown quantity at this point
I was just wondering, for those that have mounted their spare tire under their cars.....how much space under the car is there? Like when you go over speed bumps does it ever have a chance of making your car bottom out on it? I'm thinking it can't be much worse than lowering your car with different springs and such.....i like the idea of not having a spare in the trunk so that i can have much more space, i just don't want it to be a pain in the **** when it comes to having to be careful where i drive it.
Old Mar 9, 2003
LudlamTheory's Avatar
i boogie for the raindrops
sedan or coupe?
Old Mar 9, 2003
tom1178's Avatar
2002 coupe
Old Mar 9, 2003
Island2K2's Avatar
Island2K2 is an unknown quantity at this point
i got a 2k2coupe with my tire relocated and ive never had a problem hittin anything
Old Mar 9, 2003
ce01cvcex's Avatar
ce01cvcex is an unknown quantity at this point
it might not be a pain when you are driving, but it makes for getting your spare out if you need it interesting. i actually used an old assembly from a pick-up that had the wire and a crank to make this easier on me. it requires a little more work, but it is worth it, IMO, in the long run, mainly cause i don't have to crawl under my car if i need my spare, i put the rod in there, and crank it down and remove the spare.
Old Mar 9, 2003
jefff's Avatar
jefff is an unknown quantity at this point
Quote
[hr]Originally posted by: ce01cvcex
it might not be a pain when you are driving, but it makes for getting your spare out if you need it interesting. i actually used an old assembly from a pick-up that had the wire and a crank to make this easier on me. it requires a little more work, but it is worth it, IMO, in the long run, mainly cause i don't have to crawl under my car if i need my spare, i put the rod in there, and crank it down and remove the spare.[hr]
That's the best idea I've heard yet!! Do you have any pics of this?
Old Mar 9, 2003
GanariGuY's Avatar
GanariGuY is an unknown quantity at this point
how do u guys get ur spare if u guys have a kit and it's lowered?????
Does ur spare hit when ur car is lowered,
and how do u get under the car to get to ur spare???
Old Mar 9, 2003
WhiteRabbit's Avatar
i dunno about a kit, but my car was (is) lowered, i had no *real* problems, after i too realized that getting the tire out would be a pain, i pulled it off, i want to set mine on the side like 2k1civic.com's civic, but ive been pretty lazy and havent gotten around to it yet. would fix everything tho.
makes more sense to pull it to teh side, other than the fact that its alot more work......
Old Mar 10, 2003
ce01cvcex's Avatar
Quote
[hr]Originally posted by: jefff
Quote
That's the best idea I've heard yet!! Do you have any pics of this?[hr]
no, unfortunately, i do not, i don't have a digi cam, and no one else i know does... but it's pretty easy to do, just take a look under a pickup, and look how it's assembled, then go to a junk yard and find a working assembly, and buy it i got mine for about 10 bucks i think it was. then, you just bolt it up and make sure everything still works, and there you have it. also, i didn't drill a hole in my bumper like most trucks, i simply mounted it behind the bumper. yeah, you have to bend down to do it, but at least you don't have to crawl under the car...
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
bsmiley
Apr 27, 2015 01:27 PM
bo_red
Apr 23, 2015 10:09 PM
GH04si
Apr 15, 2015 08:13 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
