Amp. Battery Wire
Old Mar 8, 2003
kreasone's Avatar
kreasone is an unknown quantity at this point
Amp. Battery Wire
Does anyone know of the best possible spot to run my amplifier's battery wire through the fire wall.
Thanks
Old Mar 8, 2003
dragoon's Avatar
Check the DIY. There is a rubber gromet under the carpet in the front passenger side.
Old Mar 8, 2003
Mbow's Avatar
Yea, we lucked out with that one. It's easy to get to and plenty big enough for a good size wire.
Old Mar 8, 2003
AFlyer's Avatar
AFlyer is an unknown quantity at this point
i have 4 AWG wire running through that grommet with plenty of room to spare. run power down the right side of the car and RCA (if you have them) and remote turn on down the left side. really easy install.
Old Mar 9, 2003
DizWikedCivic's Avatar
power in the left side and rca in the right side
Old Mar 10, 2003
branden's Avatar
branden is an unknown quantity at this point
yep, power on the right. RCA on the left but mines in the middle coz the amp is under the front passenger seat.
from the battery and fuse housing theres a rubber seal on the left side of the engine bay where wires from the ECU also pass.
Old Mar 10, 2003
i ran my rca down the middle console, becuase my brain is under the passenger seat, and have my power cable on the right side, and i have a lil bit of a whine but it not that bad
Old Mar 10, 2003
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
rubber gromet under the carpet on the passengers side. Use a hanger and poke it through the gromet into the engine bay, when you get it through the engine bay, tape the power wire to the hanger and pull it through into the inside of the car.
Old Mar 21, 2003
Jackseric's Avatar
Jackseric is an unknown quantity at this point
I just ran my power wire down the passenger side and the **** is interfering with some radio stations. I started noticing that if I tune in a radio station with a weak signal it started getting really staticy and sounding like crap. So I hit the amp cut-off switch I installed and the radio station comes in loud and clear. I'm pissed... I suppose it's because my power wire is running parallel with the antenna. So now I get to tear down the whole car again and move the power wire to the drivers side.
Unless... Do you think I could just wrap either the power wire or the antenna in aluminum foil or something that would shield it from the interference?
Any ideas?
Old Mar 22, 2003
Ed's Avatar
Ed
There's a metal called mumetal that's known to reduce electro magnetic transmissions, it's commonly used to insulate these things. try a search for that.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
trellex
Jun 30, 2015 07:13 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
Chuck94527
Jan 31, 2002 07:49 AM
LuvMyCivic
Dec 12, 2001 10:02 PM
