DIY Where's the rear speakers for coupe? (I SEARCHED)
Old Feb 23, 2003
aldini's Avatar
aldini is an unknown quantity at this point
I can't seem to find the diy to remove the rear deck from the coupe
Old Feb 23, 2003
dragoon's Avatar
1. fold down your rear seat
2. between the seats there will be 2 10mm bolts behind a carpet thing. remove those.
3. after removing those, you can remove the passenger side part of the rear seat. there will be another 10mm bolt near the 2 you removed that will allow you to take off the bracket and remove the driver's side of the seat.
4. there are 2 14mm bolts at the bottom of the seat belt. one is attached to your rear quarter panel. remove that one. you will have to loosen the other one as you do it, but you don't need to remove it.
5. behind the handgrip thing on the rear quarter panel is a small indentation. pull that back, and under it wil be a small phillips screw. remove it.
6. on each c-pillar (the back ones by the rear window), there are little panels on them you can remove. one side has a bigger one than the other. after removing those, you can pop out the c-pillar panel.
7. after removing that, there are two strange plastic toothed things behind where the backseats' backs are that you gotta pull out. i never bothered to put mine back in becuase they're gh3y.
8. when you get those out, you can proceed to pop out the rear quarter panel.
9. after that's gone there is a bolt holding in the rear deck on each side, and the rest is just clips. don't forget the 3 clips along the bottom of the deck that you have to manually open first.
that should be it, most of the steps have to be done twice (once for each side of the car)
Old Feb 23, 2003
ce01cvcex's Avatar
ce01cvcex is an unknown quantity at this point
its the same as the sedan... its a biotch the first time you do it too...
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
shindrome
Exterior
May 5, 2015 02:50 PM
PimpBot5000
Nov 26, 2001 07:15 PM
BabyLX
Nov 16, 2001 05:53 PM
ademarco6
Nov 12, 2001 06:52 PM
