help! i f*$#ed up my door lock!
Old Feb 22, 2003
CivicFerio's Avatar
CivicFerio is an unknown quantity at this point
i need help! i was replacing my front speakers.. and when i put the door panel back the lock wont fully go down to locking position.. but when i close the door and lock it either by keyless entry or when im inside and use the central locking button it goes all the way down but it sounds different.. can someone help me? im not sure if this thread is in the right category.. i need help.. thanks! and oh.. if i bring my car back to honda and they see that i opend the door panel will they charge me?
Old Feb 22, 2003
AlpineCivic's Avatar
Actually thats the way they factory doorlock works. It will only lock when the door is closed to keep you from accidently looking your keys in your car. So dont worry fella its all good![IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Feb 22, 2003
CivicFerio's Avatar
no man! it sound's weird now! and it's kinda loose.. i mean the locking thing itself.. i tried to look at the other door and the lock isn't that loose.. that's why i haven't chaged my passengers side speaker yet because im afraid i might f@ck that up too!
Old Feb 22, 2003
slowlx2k2's Avatar
slowlx2k2 is an unknown quantity at this point
pull your door handle on the inside of your while holding that out press your lock button. that should do the trick. When i first did a set of speakers in my honda it was the first time I had ever done them. I thought I screwed it up to but I didn't
Old Feb 22, 2003
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
pull your door cover back off. I had this same problem and there is a small metal mount sticking out from the door. There are two white plastic pieces under the actual lock that sticks out of the door, the plastic piece on the bottom is flat, and the top piece is rectangular. You need to wedge the mount in between those so that it is held securely. Hopefully you understand what I mean. The thing about this though is that it is hard to put the door cover back on without the lock coming loose from that mount, so you have to be carefull and try many times before you get it right.
Old Feb 22, 2003
CivicFerio's Avatar
2 plastic pieces? ok i'll check.. thanks for all the info! hopefully i will be able to see that..
Aladinbama
Aug 23, 2015 06:37 AM
viperGTS
Jul 27, 2015 08:40 PM
ayoitzjulesdx98
Jul 26, 2015 02:25 PM
ballmich
Jul 9, 2015 11:59 AM
Spanky4269
Jul 5, 2015 09:40 PM
