Hardwiring accent lights?
Old Feb 18, 2003
born2xLr8's Avatar
Is it possible to hardwire accent neons (neons that plug into your cigarette lighter)?
Will cutting off the cigarette lighter plug be sufficient?
If this is possible, can someone give me schematics or a small DIY of the procedure and required parts (i.e. transformer?..switch type?...wire connectors?...etc.)?
I have absolutely no knowledge in wiring so I need lots of help or advice and this is actually a friends question.
I've already done a fairly detailed search I didn't come up with answers.
Thanks
Old Feb 18, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
You cut off the cig lighter plug on the neon transformer, and use tap-in style connectors to tap the positive to positive, and negative to negative on the cig lighter wires behind that panel in the console. If you have alot of neons to hook up, I would suggest a larger power wire brought in from the firewall, and use a relay to the cig lighter wire. Thats if you want them to turn on with the car....a switch could also be used. PM me if you want details on any of the options you have, and the type of car. Mine are hooked up with a relay.
Old Feb 18, 2003
ce01cvcex's Avatar
ce01cvcex is an unknown quantity at this point
i tapped mine into the fog light switch, you will need a test light, go into the back of the plug, and click it off, then test to see which ones are hot, i think there was 1 that was still hot, then, click it on and test the ones that weren't hot before, tap into the one that lights up once the switch is on with the positive wire, and the negative to a ground or a negative wire, i used the negative wire, then you have a switch for them, with no need to drill a hole for an additional switch, mine works perfectly fine.
Old Feb 18, 2003
born2xLr8's Avatar
Thanks for the help.
-Where is the neon transformer? Is it in the light bar?
-Is a relay still required if a switch is being used?
-If a switch is being used, where do you tap in to get power?
ce01cvcex....I don't have any existing switches so....
Old Feb 19, 2003
WhiteRabbit's Avatar
Quote
[hr]Originally posted by: born2xLr8
Thanks[hr]
serched the wrong forum! i made a VERY complete step by step in the Tech forum, had to do with relays and suck, but your question was DEFINITELY covered there!
may have to hunt around, cause my DIY's tend to get lost in the archives.....
Old Feb 19, 2003
born2xLr8's Avatar
WhiteRabbit....I take it this is it? thanks for the heads-up. Knowing your username made the search easier.
MyCivic
Electrical
Oct 28, 2021 11:06 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
Blazz
May 25, 2015 10:56 PM
werdnahall
May 17, 2015 11:37 AM
davidarenberg
May 16, 2015 08:45 AM
