Fans
Old Feb 12, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
Fans
Hey guys, in a week or so i'm starting my trunk, and since all my amps are gonna be under plexi, I need to ventilate them. I've been researching for a couple weeks, and it seems like a "squirrel cage fan" is the way to go...whisper quiet, and tons of air flow. I'm gonna set it up with a relay that gets tripped by the remote turn on for the amps. Anyway, does anyone know of a place where I can get one for a good price? Audiolink said $50, but I donno if thats high, low, or good?
Thanks,
Mystic
Old Feb 12, 2003
LudlamTheory's Avatar
i boogie for the raindrops
thayre also known as crossflow fans... might be easier to find em that way... but to be honest, just get some computer case fans... a lot cheaper
Old Feb 12, 2003
Mystic3030's Avatar
I looked into the computer fan area, and they are all quite loud compared the squirrel cage fan....I want something thats silent.
Old Feb 12, 2003
666's Avatar
666
666 is an unknown quantity at this point
Try selectproducts.com, they have alot of hard to find stuff.
Old Feb 12, 2003
bzrollin's Avatar
bzrollin is an unknown quantity at this point
Ive seen brand new Stinger crossflows on ebay for about $35 shipped
Old Feb 12, 2003
OyD's Avatar
OyD
OyD is an unknown quantity at this point
i got my 2 fans for $7CDN each from a surplus store
i don't think you can use computer fans because they are 120V not 12V
Old Feb 12, 2003
Quote
[hr]Originally posted by: OyD
i don't think you can use computer fans because they are 120V not 12V[hr]
nope... everything in a pc runs at 6 and 12 volts (4 i believe also), but computer fans run at 12 volts
Old Feb 12, 2003
KD5FTN's Avatar
KD5FTN is an unknown quantity at this point
Quote
[hr]nope... everything in a pc runs at 6 and 12 volts (4 i believe also), but computer fans run at 12 volts [hr]
Actually the PC AC-DC power supply outputs voltages at 12VDC, 5VDC, and 3.3VDC. All molex connectors (the ones that go into your components contain both 12V and 5V connections. So most likely PC fan is at 12VDC, perfectly compatible for mobile use.
Old Feb 12, 2003
Quote
[hr]Originally posted by: KD5FTN
Quote
Actually the PC AC-DC power supply outputs voltages at 12VDC, 5VDC, and 3.3VDC. All molex connectors (the ones that go into your components contain both 12V and 5V connections. So most likely PC fan is at 12VDC, perfectly compatible for mobile use.[hr]
i knew it was around 6 and 4 volts, i guess 5 and 3.3 is close enough...
Old Feb 12, 2003
Subrage's Avatar
Subrage is an unknown quantity at this point
does it really matter about how loud it is, when you have your stereo on, and its in the trunk ???
Old Feb 13, 2003
Mystic3030's Avatar
Quote
[hr]Originally posted by: Subrage
does it really matter about how loud it is, when you have your stereo on, and its in the trunk ???[hr]
I plan on showing/competing with the vehicle when it's done, so yes, when it's sitting with the stereo off or at low volume with the trunk open, I dont want fan noise in the trunk.
Old Feb 13, 2003
Subrage's Avatar
i plan on competeing, some days down the line, but under plexi you wont be able to hear it.
IMO if you get the stingers for 40 or what not your just throwing you money away
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
h4ldol
Apr 24, 2017 08:16 PM
solarpunk70
Apr 12, 2016 11:43 AM
anubis62
Sep 27, 2015 12:56 AM
hondalx2002
18
Sep 15, 2015 10:54 PM
