need help with amp
Old Feb 9, 2003
coolness5545's Avatar
coolness5545 is an unknown quantity at this point
need help with amp
ok when u put the power wire from the outside to the inside passgenger side. where do u put it through at i read the diy and am not sure if he means behind the velcro or to the left of the velcro where all th other wires are. also do you need to remove the side panels in the backseat to run the wire through or can u just shove it through there?
thanks,
chris
Old Feb 9, 2003
another thing i realized is that my head unit doesnt have rca jacks. is there a way to still hookup the rca or no? thanks
chris
Old Feb 9, 2003
Ed's Avatar
Ed
I'm not sure what you're talkign about.. but if you're tryign to put the power wire through the firewall, you can put it through the grommett in the footwell of the passenger side.
to hook up an amp to a HU that doens't have RCA outputs, you can either splice the rear speakers to the amp's line level imput (if it has them) or get a line level convertor to convert speaker level wires to RCAs.
Old Feb 9, 2003
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
Pull the carpet back from up under the passenger side and over kind of to the left you will see a place where many wires pass through a rubber insert into the engine bay. Just get a hanger and push it through that insert, it may take a few times to get it through, just don't force too much if it won't go. After you get it into the engine bay, tape a good amount of the power wire to the hanger and slowly pull it back inside the car, this may also take a few times. Hope this help!
Old Dec 1, 2003
jsiu85's Avatar
jsiu85 is an unknown quantity at this point
YESSSS!!!!! thank you ZSKCivic01!!!! I've been trying to find an answer for my question for a long time!!! I was wondering the same thing about the passenger side hole. I thought it was behind the velcro peice so i cut a square shape peice out and started poking at it but it was solid metal! I was like WTF!?! where's this hole that every one is talking about but then I noticed the bundle of wires to the left and tried that... PRESTO! it worked.. I just wasn't too sure if that's the hole everyone was talking about.
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
wingsfan19
Oct 1, 2015 03:45 AM
Mc7602
Sep 17, 2015 02:01 PM
redcloud
Sep 7, 2015 01:45 PM
