Need Help Now!: Best Way to Pull Out Dash Piece
Hey guys. Whats the best way/angle to pull out this piece with the air conditioning controls, etc. I think I may have cracked it pulling from the bottom so hard, and yes I have the screws off. Help?
I just did it this weekend, and let me tell you, the rear deck was cake compared to taking the radio out. Sure, I followed what I had read on the board, but no amount of muscle was getting the deck out of the dash by pushing fro behind. Those clips are solid.
The best method I found was to release the glove box so it hinges all the way down. You can gain access to the deck from there. I used a flat head screwdriver to pry the bezel away and a few of the clips released. At this point I was able to pull on the dash bezel by hand. Just work your hands around the outer edge. I had the toughest time with the top three clips. Don't be afraid to pull hard. It takes A LOT of effort to get that thing out.
Good luck!
Good luck!
i used this ice scraper i got from my dealer, it doesn't scratch anything, and works so easily. i just started at the bottom left, where the a/c fan control **** is, and worked counter clockwise, took me a minute, but i didn't have to work hard to pull it out.
i wouldn't use a screwdriver or anything like that, it will most likely leave scratches and marks around your dash, the ice scraper, or something similar ( long, flat plastic head ) should work fine.
mohawkboom
67
Aug 25, 2015 12:28 AM
EdGasket
May 25, 2015 01:06 PM
cooldan1
Apr 23, 2015 10:49 AM
Dmitri
123
Oct 13, 2005 08:01 PM
