Stock CD Player hook-ups..
I was given a JVC 12 Disc CD Changer Model # CH-X11 and i was wondering if i can get it to hook up to my factor cd player.. i also have a Mobil DVD Player hook-up using an FM adapter. anyhelp would be great...
Ex_ZaCc
Ex_ZaCc
To hook up your changer you need one of 2 things....either an FM modulator (which plays the sound through the radio) or you need an adapter to connect the two. I am not aware of any adapter that connects a JVC to a factory head unit, so the FM modulator is probably the way to go. The install is pretty simple, just providing a fused power source that is constant, a switched source and of course a ground. All you do is then find a junction for the antenna and then connect it with the modulator. The unti will have a seperate control which you mount somewhere the car and thats it......all you do is tune in the radio station its set to and you have the sound....now to be honest there will be a loss associated with it as the radio doesnt have the accoustic range like a CD..but it will still be better than tape or radio
Good Luck
Good Luck
NoobyKid
Jul 13, 2015 07:53 AM
