Good SQ Sub for under $300
Old Dec 28, 2002
GoCivicRacerGo's Avatar
GoCivicRacerGo is an unknown quantity at this point
I want to get one 12" sub just for some bass in my car. It will probably run off one of the bridged channels on my 6304 amp. So approximately 160-200 watts. If that does not work out I will run it off an MTX 8302. I want it to be a dvc 4 ohm. I will make the box so that does not matter in choosing the sub. Any suggestions? SQ is all that i'm after. I went to woofersetc and was overwhelmed by their choices. I was looking at ARC, Focal, JL, ID, Audiomobile, Alumapro, Eclipse, Kove, any others I should consider? Thanks!
Old Dec 28, 2002
mohawkboom's Avatar
If your gonna bridge a class A/B amp to one sub..you want an SVC 4ohm sub..otherwise you'll run a 2ohm mono load which will toast your amp...
For that price range an IDQ12v.2 would probably suit you best
czarlun
Jun 20, 2015 08:55 PM
civic1316
May 29, 2015 05:13 PM
autowill
May 15, 2015 11:36 AM
superstanko
Apr 28, 2015 04:38 AM
