got my comps.. now what kinda amp?
Old Dec 27, 2002
HaLcYoN's Avatar
HaLcYoN is an unknown quantity at this point
Hello,
I just got my components and 6 x 9's... (comps: Alpine SPR-176A... 6x9: Alpine SPR-694A)
2 questions:
Should i get two 2-channel amps or one 4-channel amp? and which do you recommend? (i would like to run them powerful but still clean)
2nd question:
At how many hertz should i cross them over?
(technically those were 3 question -_-)
Old Dec 27, 2002
LudlamTheory's Avatar
i boogie for the raindrops
1 4 channel is always easier and cheaper...
Old Dec 27, 2002
DizWikedCivic's Avatar
since you got alpine speakers, you can get a alpine amp most of their amps are 1/2/3/4 channel amps, it got their own gain and crossover control for each channel
Old Dec 27, 2002
mohawkboom's Avatar
Well generally 4 channel amps have 1 Highpass filter..and one low pass filter..So you'd be able to highpass your fronts (70-90hz) depending on the set you have and how loud you listen to it..
For the rears, unless you find an amp with a HP and LP filters on each end, you'd need to use you HU's High Pass filter, or get a Bass Blocker,,(small capacitor) and wire it inline with your rear speakers..preferably one tuned to highpass at 90Hz at a 6db(or12)/octave for the rears.
Two 2 channel amps will give you more flexibility but to run the same power would generally cost more. If you want the pretty much highest quality 4-channel amp that's still somewhat reasonable in price you might want to look into the Arc Audio 4150CXL-R ..it's fully microprocessor controlled and many top SQ competitors went out and bought one as soon as they heard one..
like Rick McCallum, Leon Shing, Mark Bruno, Matt (Idteg on sounddomain forum)...they are very awesome amps..
Old Dec 27, 2002
Mystic3030's Avatar
Yup, i'm an A$$hole.
I personaly love PPI for highs....Phoenix Gold is pretty good too, although a little overpriced. The PCX480 has two crossover settings, as does the PCX4125....I'm not sure about the PCX440.....
The PCX amps have crossover controls for all four channels, and the preouts....seriously awesome amps......www.buyloud.com has good prices on them if you want em from the web.
-Mystic
Old Dec 28, 2002
HaLcYoN's Avatar
Where can i get the Arc Audio 4150CXL-R online? for the best deal possible?
thx
Old Dec 28, 2002
mohawkboom's Avatar
well the arc 4150 is $816 off ampmanaudio.com
the PPI 480 is only $389 at onlinecarstereo.com
Old Dec 28, 2002
ohiojosh78's Avatar
ohiojosh78 can only hope to improve
pheonix golds have less than .001 i have a TI500.4 VERY happy
Old Dec 28, 2002
mohawkboom's Avatar
anything under .5% distortion is virtually inadible...there are more factors to amp than it's THD..such as signal to Noise ratio, Damping factor, resistances on the board..
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
Mc7602
Sep 17, 2015 02:01 PM
redcloud
Sep 7, 2015 01:45 PM
