Double Din
Old Dec 21, 2002
BlueIce2001's Avatar
BlueIce2001 is an unknown quantity at this point
Double Din
just turned my console into a double din setup for my HU and digital EQ
it looks ok now i just need a new HU since i was tryin to just relocate the face i was goin to use one of my old HUs that only had 8 pins
well try to get some pics up soon
Old Dec 21, 2002
ohiojosh78's Avatar
ohiojosh78 can only hope to improve
Sorry i'm a smartass, but actually our openings ARE double DIN sized. you just turned your cd player opening into a 1 DIN and EQ 1 DIN
Old Dec 22, 2002
DizWikedCivic's Avatar
yup are console are double din size
Old Dec 22, 2002
HRocket2k2's Avatar
HRocket2k2 is an unknown quantity at this point
I got a dvd and reciever in my slots i need a double din dash kit!! anyone got any info on that?
Old Jan 3, 2003
03_silver_ex's Avatar
03_silver_ex is an unknown quantity at this point
metro makes a dash kit for double din.
Old Aug 23, 2003
emajndat's Avatar
emajndat is an unknown quantity at this point
As far as i see Metra DOES NOT make a double din kit for our cars. I am having the same problems as most others. I have two din sized radios and I want to convert the one din to two. If anyone has ACTUALLY done this PLEASE let me know I need pictures as a guide. THanks
Old Aug 23, 2003
alex053's Avatar
i have done it. PM me.
Old Aug 23, 2003
Boiler_Room's Avatar
Boiler_Room is on a distinguished road
Can we see pics of your double DIN ?
Old Aug 23, 2003
alex053's Avatar
no digicam and right now its outside in primer...sorry. ill bring it to the az bbq meet and have falken snap a pic of the current status.
Old Aug 24, 2003
biohazard's Avatar
biohazard is an unknown quantity at this point
I saw some cheap ones on Ebay. I don't know if they're the right ones to serve your purpose:
http://cgi.ebay.com/ws/eBayISAPI.dll...category=32812
Just looked up keywords "civic dash kit" and had to look through all the other trim kits to get to find it... I'm sure there's more out there.
Old Aug 24, 2003
biohazard's Avatar
Also, I found this somewhere else in the forums:
http://www.partsexpress.com/pe/showd...D=117780&DID=7
Old Aug 24, 2003
emajndat's Avatar
All those links are for single din, but thanks for the effort
I need a picture of someone with a double din custom job so i can get more of an idea
Old Aug 24, 2003
biohazard's Avatar
I thought the other part was a pocket that could come out, becoming a 2 din. Am I mistaken? Isn't that how you make it a 2 din in most dash kits? Except that in most others, it's just a flat panel... this one is a little more useful and has a pocket... no?
Old Aug 24, 2003
alex053's Avatar
Rbabe took a pic of my dash piece today.....ill link to it when she has it up.
Old Aug 25, 2003
alex053's Avatar
here it is before...single din, notice the line where the kit meets the dash...
Old Aug 25, 2003
alex053's Avatar
here it is after..no line..all one piece, two din openings, primered and almost paint ready.,
Name:	dash piece.jpg
Old Aug 26, 2003
emajndat's Avatar
sweet, but what did they use to fill in all the gaps...ect but it looks really good and perfect for what i need it for
Old Aug 27, 2003
alex053's Avatar
i used mar-glass for the large gaps....here are the steps i took
1. trace old instal kit onto 1/2 inch wood and cut it out, make sure it fits in the old hole
2. double side tape 1/4 abs plastic to the wood and router it so you have that same piece out of plastic now
3. measure size of radio so you know how big to cut the hole for the deck (i had a template for this thanks to RTTI)
4. double side tape the template to the abs, being sure its in the right spot in relation to the iso mount of the radio...if the hole is off nothing will line up
5. take it over to the pin router and cut the openings.
6. clamp your new routered abs plastic piece into the hole that once held your instal kit.
7. glue the plastic in using 2 part epoxy ( i used hot stuff found at www.installedge.com)
8. fill in gap using marglass and sand smooth.
9. primer, sand, fill in any pin holes with bondo
10. sand, sand, sand repeat then prime and paint.
it hink thats about it....im pretty tired and did that from memory..ill edit it or answer any questions.
Old Aug 28, 2003
emajndat's Avatar
Sounds like you did a good job, if i paid you, would you be interested in doing it to mine, i would ship you my piece, and pay to get it shipped back? Im at school and have no resources to get it done, and all the shops here are clueless.
Old Aug 28, 2003
syndrome's Avatar
syndrome is an unknown quantity at this point
same situation with me, I'd deffinately pay for a job like that to my dash. Tweeter was dumbfounded about doing this kind of job, and said that any attempt would cost upward of 300 bucks..
Old Aug 28, 2003
alex053's Avatar
well i dont have access to any of the tools...sorry guys.
its a one off piece because just the rockford face will show thru so if you had an alpine there might be a big gap. i would need both units, your dash and the metal part the headunit mounts to. make a custom mount to put them where i want em then router out a hole the size of your particular equipment. $300 sounds resonalble since it took me about 7-10 hours before i even primered it.
Old Aug 29, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
Go to a real custom audio shop, not Tweeter.
It should cost anywhere between 200-300 bucks to have something like that made.
Old Aug 29, 2003
biohazard's Avatar
Question:
So you created a new one out of ABS, not modified an existing one? If so, where'd you get the ABS for it? Do they just sell it? How much? And how would you get it to curve the way you needed?
If you modified it, I guess that would sound simpler, but I'm still not sure (even with the steps listed... guess I'm dense).
And why don't they sell the trim for the lower pocket? If there are so many Civics out there, don't you think they'd have an accessory like this? It's so lame....
Old Aug 29, 2003
AlpineCivic's Avatar
I did the same thing Alex053 did, but just a little different. From what I can see from his picture the whole piece is flat my dash actually curves to the shape of the radio and EQ but used the same steps he did, I'll post some pictures tonight so you can see
Old Aug 29, 2003
alex053's Avatar
biohazard: you can get abs at most home depots or stores that are similar to that. the shop i did it has everything on hand (its where they build the demo cars for rockford fosgate) you cant modify the existing piece doesnt have a large enuff opening and you would do more work cutting out the pocket and trying to cut that opening to fit...easier to make a new piece.
CantSeeMe: my piece curves also. Thats why i used 1/4 inch so that i could clamp it in the place of the facotry opening and it would follow the same curve. i would love to see pics of yours. every pic i see it looks unfinished but you have an awesome system.
Old Sep 2, 2003
emajndat's Avatar
Pictures please, i need to do something quick cause im sick of sitting here with both units and i cant put them in. THanks again guys
Old Sep 3, 2003
alex053's Avatar
thats the only pic i have until i get a digicam...pm me with any questions on the steps i took to make it.
Old Sep 3, 2003
Here's some pictures please excsue the dusty radio...
Old Sep 3, 2003
another...
Old Sep 3, 2003
and another...
