where's my antenna amp?
Old Dec 4, 2002
scottf's Avatar
scottf is an unknown quantity at this point
I'm having reception issues, and I've seen a few posts about checking the connection to the antenna amp in the c pillar (between rear window and small backseat window). Well, I opened up the passenger side c pillar last night ('01 sedan) and couldn't find any antenna anp. I saw where what I think was the antenna wire was running up through that area, but not connecting to anything. Then I thought I might have opened the wrong c pillar, so I checked the driver-side c pillar... nope, not there either. Am I looking in totally the wrong place?
Old Dec 4, 2002
fonto's Avatar
The LA Clipper
I get horrible reception too, especially when I am in grid lock traffic (which is every day in LA).
Anyway, I believe the actual antenna amp was on the radio itself. Once you take out the stock radio you virtually lose all AM reception [IMG]i/expressions/face-icon-small-sad.gif[/IMG]
One thing that you may want to check is to see if all of the atenna connections are still together properly. The three connecting points that I have seen so far are: behind the radio (ofcoarse), in the passengers kick pannel, and in the back side passengers pannel. I would check these to see that no wires are lose. I need to check mine too because I have been getting bad reception lately!
edit: that wire that you say is loose in the C pannel should be connected...when you do that you will get your reception back
Old Dec 4, 2002
scottf's Avatar
The weird think about this situation is that I had great reception with the old and the new HU. My reception just got bad all of a sudden, which made me think that maybe something came loose. Something else weird is that I have good reception if the car has been off for a while. I'll have my normal good reception back for about 30 seconds to a minute and then I loose it again.
Old Dec 4, 2002
AlpineCivic's Avatar
Alright Let me take to antenna school for a bit[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
First anytime you change any factory radio reception is lost! Sucks dosent it? Some cars worst then other's. All this is the resault of resistance changes in the vehicle and antenna (short way of saying it without getting techincal) now our cars do have an antenna amplifier and can simply be turned on by putting power to the wire on the factory radio harness when your radio is turned on. The wire should be a Yellow/Green wire.
Old Dec 4, 2002
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
what wire would that correspond to on an aftermarket harness
Old Dec 5, 2002
Elite's Avatar
Elite is an unknown quantity at this point
First of all let me tell you cuz I actually saw it and know where it is, its on the back left of your car as in facing the back of your car, take off the side and whollaa you got it.
Old Dec 6, 2002
ChiZX's Avatar
ChiZX is an unknown quantity at this point
Quote
[hr]Originally posted by: scottf
I'm having reception issues, and I've seen a few posts about checking the connection to the antenna amp in the c pillar (between rear window and small backseat window). Well, I opened up the passenger side c pillar last night ('01 sedan) and couldn't find any antenna anp. I saw where what I think was the antenna wire was running up through that area, but not connecting to anything. Then I thought I might have opened the wrong c pillar, so I checked the driver-side c pillar... nope, not there either. Am I looking in totally the wrong place?[hr]
In my 2001 Coupe LX, it's in the right upper rear panel between the back windshield and the small side windshield. You'll have to remove the side panel to get to it. If you do the steps for the DIY for rear deck speakers, you'll be able to see it. It looks like a black box about the size of a deck of cards. I believe this is the antenna amp. Can someone back me up?
Cheers [IMG]i/expressions/beer_yum.gif[/IMG]
Old Dec 6, 2002
ChiZX's Avatar
It must be somewhere else in your sedan. It is in the C pillar for the 2001 coupes. Sorry I can't help you find it since I don't have a sedan.
Old Dec 20, 2002
Quote
[hr]Originally posted by: CantSeeMe
First anytime you change any factory radio reception is lost! Sucks dosent it? Some cars worst then other's. All this is the resault of resistance changes in the vehicle and antenna (short way of saying it without getting techincal) now our cars do have an antenna amplifier and can simply be turned on by putting power to the wire on the factory radio harness when your radio is turned on. The wire should be a Yellow/Green wire.[hr]
i bought the metra wiring harness and i dont see that wire on the kit. there is a blue wire labeled power antenna is that it?
Old Dec 21, 2002
Abstract's Avatar
Abstract is an unknown quantity at this point
yes it is teh power antenna lead, mine reception is just fine, of course I have turned on Fm radio since I got Xm and probably never will.
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
wingsfan19
Oct 1, 2015 03:45 AM
Mc7602
Sep 17, 2015 02:01 PM
redcloud
Sep 7, 2015 01:45 PM
