whats the deal here...
Old Nov 22, 2002
prototype's Avatar
x-factor
i was out in my car today and i had the radio on....didnt have the car running...just on the accessory had it on really low and after about 15 mins it shut of....the car died i waited like 1/2 hr and then started the car took a second but it started then i let it run for a lil while. my system consists of a P.O.S. amp 600 watt and 3 rockford 12's i dont know what happened and how can i fix the problem im stumped [IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Nov 23, 2002
Litespeed's Avatar
Litespeed is an unknown quantity at this point
You're battery must've been low to begin with. Do you have your stereo up loud during the majority of your driving? You may be pulling more current from the battery than you are putting back in with your alternator. This shouldn't be a problem Or if you listen to your stereo a lot without your car running even though on low volume levels. At night with all your lights and and whatnot you battery is being used even more so having your stereo on doesn't help your alternator in charging your battery. You could get a yellow top which will help a little cause it is a deep cycle and holds more charge. But your POS 600 watt amp still pulls decent current from the battery.
Old Nov 23, 2002
prototype's Avatar
x-factor
yea i was thinking getting one of those optima batts but i dont know hat kind ive heard red top and yellow but i dunno whats the correct one...also would a cap help me out too? thanx
Old Nov 23, 2002
STang57's Avatar
STang57 is an unknown quantity at this point
a cap would help but it also puts a tiny strain on your batt. but i doubt it will matter with a deep cycle batter if you buy one. the only problem with deep cycle batteries is that IF it ever dies, it will take i think 10 hours to fully recharge?
Old Nov 25, 2002
DBDIJON's Avatar
DBDIJON is an unknown quantity at this point
Yellow Top Optima is deep cycle application, where you repetedly kill the battery and the recharge. Red Top Optima is a higher output (higher CCA and amp/hour) rating. If you are running only one battery in the car go with a RED Top. If you are running multiples put a Red Top as your starting/primary battery and yellows as an aux.
A Capacitor only helps if there is current to charge it. To sit longer with the car off you need a bigger battery. To just have better bass anytime you need a cap.
Luluharp
Sep 27, 2015 11:56 AM
