How to take out STOCK DECK
Quote
[hr]Originally posted by: T
How DO I TAKE OUT MY STOCK deck without damaging the FRAME and stuff??? is there a site that shows you w/ PICS and stuff????[hr]
Alright let's start off on the center consel: remove the two clips in the front on each side by pushing in the center of the clips and then pull them out. Next: remove the two phillip screws at the rear of the consel ( one on each side) Next: pull out the poket noe be carefull you dont want to scratch anything under there you will find two screw's and take those out. (if you have a M/T the boot needs to be pushed down and the shift **** taken off)
now take out your center consel. Next remove the piece where the pocket and lighter adaptor go. it's just clips so just pull on it carefully! Next: you'll find 2 8mm bolt's remove those and your whole radio assembly is ready to come out. now what I do is tilt the vents down, put my fingers through and pull or you can use a panel removing tool but that can leave marks on your dash but becareful because the clips that hold the piece in can pop off and the whole piece wont go back in right, I think you can figure it out from there...Good Luck Hope it helps.
NoobyKid
Jul 13, 2015 07:53 AM
Jul 12, 2015 11:54 AM
BootyDo
Jul 7, 2015 06:06 AM
7thgensurvivor
Jul 5, 2015 12:17 PM
