Subwoofers
Old Nov 19, 2002
Marcus's Avatar
And Pimp I got the Juice
Marcus will become famous soon enoughMarcus will become famous soon enough
Subwoofers
How do I put my subs where my spare tire is, and secure them so they fit? I see in the members rides people have done it so I thought I wouyld ask, because that looks hot.
Old Nov 19, 2002
trevor's Avatar
trevor is an unknown quantity at this point
Mine was a bit of a pain in the assss to be truthfull......
I haven't seen the DIY around here, I'll explain a bit............
#1.....Take your spare out along w/ the metal peice in the tire area.....
#2.....I used 1/2 inch fiber/press board.......
#3.....take the piece of board that covered your spaare tire and trace that onto the new piece of fiber board.
#4 cut that out.....this will be your new "top"......
#5......measure the dims of the tire area.....and figure out how much air space you';ll need and build a box that will go into the whole.......
#6.....glue screw the box togther.......then glue/screw the box to the the traced out board you did earlier......
#7..then cut however many holes into the box you need........
#8 then use the carpet from the old board that cover the spare and glue to the new board.....
you can make covers or do whatever.......It wasn't that hard...just a pain in the ****......
I used some plexi covers just so I didn't ruin my subs......is not that hot..but it works......
PEace, Trevor
Old Nov 19, 2002
LudlamTheory's Avatar
i boogie for the raindrops
depends on how much airspace you need.... and dont use 1/2 inch fiber board... ewww... 3/4"MDF ... let me know what kinda subs youre gonna run in there and i can maybe throw some dimensions your way
Old Nov 19, 2002
Old Nov 19, 2002
trevor's Avatar
Quote
[hr]3/4"MDF [hr]
I was gonna run that.....to heavy though......(not that it's not heavy allready)[IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Nov 19, 2002
anything thinner and your box is probably flexing.... bad bad bad
Old Nov 19, 2002
mohawkboom's Avatar
5/8" Furniture grade plywood would be the way to go then..it's strong and lot lighter than MDF..you'd still have to brace it though. pretty much just running 1x1" boards across the center of the box to keep the walls from flexing..
this will keep it light..and strong.. Sraying in a whole can of Dynaliner, or Cascade V-block will help to deaden it as well..
Old Nov 19, 2002
01civic911's Avatar
01civic911 is an unknown quantity at this point
it looks hot as hell, but lacks horribly in sound, i built boxes to exact specs of what they should be for my subs, sealed the airtight, sounded horrible, stuffed them with filler, sounded horrible, although it looked really nice, i couldnt bear it and took it out and went back to my old box, but to each is own.
Old Nov 19, 2002
mine sounds quite good, actually sounds somewhat better to my old box that fired backwards, but i always keep my rear seat dropped if i ever feel like hearing any heavy bass... just click the link 2 inches below this post that says my hoopdie
Old Nov 19, 2002
01civic911's Avatar
Quote
[hr]Originally posted by: LudlamTheory
mine sounds quite good, actually sounds somewhat better to my old box that fired backwards, but i always keep my rear seat dropped if i ever feel like hearing any heavy bass... just click the link 2 inches below this post that says my hoopdie[hr]
why didnt you mount your amps on the back seat, or a little cleaner, it really loses the effect of looking nice with the sloppy amp install.
Old Nov 19, 2002
trevor's Avatar
Did you use green carpet on that ludlow???.....
lookin' shweeeeeeeet!!![IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Nov 19, 2002
to answer both of you, i didnt mount the amps anywhere yet because im not done buying amps... its a surprise what i plan on doing... hehe... still gotta replace that god awful sub amp, and still gotta replace the subs too, but on my budget, stuff like this takes forever to buy...
and no, its not green carpet, its (im waiting for people to laugh at me) green velvet...
Mad Dog Tannen
Oct 19, 2016 08:12 PM
wingsfan19
Oct 1, 2015 03:45 AM
wingsfan19
15
Sep 2, 2015 02:15 AM
WLakers
May 4, 2015 06:23 PM
LudlamTheory
Jul 28, 2002 03:45 AM
