speaker cut out when loud????
Old Nov 9, 2002
madmax's Avatar
madmax is an unknown quantity at this point
Every time I turn up the volume the right front speaker cutts out and sometimes clip back in till I turn it up again......silence!
Do you think it's a conection problem or does it have something to do with my amp?
Thanks in advance!
Old Nov 9, 2002
BlueTroll's Avatar
BlueTroll is an unknown quantity at this point
i had a problem similar.... well kinda..... it would play when the volume is low... but when i turned it up.... the amp cut out...... after a while..... i figured out it was the connection to the front left speaker..... the negative connector came off..... hope this helps u.....
Old Nov 9, 2002
madmax's Avatar
That was my first idea too, but after a bit of playing around with the settings, it corrected itself (for now).
I turned the gain down a bit and everything was fine! WTF????? if the gain is too high , wouldn't that cause both speakers to cut out at the same time and not only the left one?
Any how , it s ok for the moment but this baffles me ...........any ideas....
if it was a conector then it should still cut out when the volume go way up , but it doesn't
Old Nov 9, 2002
Litespeed's Avatar
Litespeed is an unknown quantity at this point
Hmmm.... it's possible there is a lose connection inside your amp. My friend had a problem similar to that and he took his amp in to get serviced. What ended up being the problem was something was lose inside and all they had to do was solder it together.
But I would check the connections to the amp and speaker first. If those are ok then I test to see if the speaker was broken. Otherwise it's probably you're amp.
nirvanaguy
25
Oct 26, 2017 07:26 PM
Mad Dog Tannen
Oct 19, 2016 08:12 PM
Gsxtacy
Sep 12, 2015 01:09 AM
redcloud
Sep 7, 2015 01:45 PM
jpat21
Sep 3, 2015 11:32 PM
