two 15" subs and amp
Old Oct 15, 2002
Nuts's Avatar
Nuts is an unknown quantity at this point
the subs are american pro and the amp is made by legacy. is this set-up any good?
TWO 800 WATT 15" WOOFERS & 1000 WATT AMP-SALE
BRAND NEW IN FACTORY SEALED CARTON
THE AMP: High power MOSFET power supply 4 Channel Bridgeable Output 4 x 250 Watts
Total Output 2 x 500 Watts Output Bridged 1000 Watts
Total Output Polished Chrome Finish w/ Plexiglass Panel
Remote Control Bass Boost 0-18Db @ 60Hz
Hi/Low Pass Crossovers
Variable Bass Boost Variable Gain Control
Gold Plated RCA Connections
Easy Access Speaker Connections
2 Ohms Stereo Stable
Soft Turn On/Off Remote Turn On/Off
Thermal Protection Short Protection Input Overload Protection
Heavy Duty Aluminum Alloy
Heatsink Power and Protection LED Indicator
15-30K Hz S/N >90Db THD <<.04% 2"x11"x11" FULL 2 YEAR MFG WARRANTY
THE WOOFERS: Don't Believe The Hype On Other Auctions That Claim They Have Off-Brand Subs That "Beat American Pro."
American Pro Makes The Finest Chrome Cone Subwoofers On The Market. American Pro Is One Of The Most Respected Names In Competition Speakers;
These Subwoofers Can Handle Enough Power To Blow The Windows Out Of The Car Next Door.
15" Chrome Cone Model By American Pro.
#WS9015 Woofer With Super High Polished Chrome Cone That Is Spectacular To Both Hear And See.
The Epitome Of Power And Durability. The Cones On These Speakers Are Chrome Injected For Toughness; Lightweight; Weather Resistance;
And Fast Constant Heat Disbursement. The Kapton Voice Coils Are Designed To Withstand Heat During Extended Hard Competition Play.
Cones Are Not "Chrome Plated" They Are Injected With Tough Durable Gold Finished Chrome In A Patented Process No Other Speakers Can Offer.
Model #WS9015 15" All-Chrome Woofer: 800 Watts Max; 400 Watts RMS; 4 Ohm Impedance; Rubber Surround; Kaptan Voice Coil;
Screw Style Terminals
WARNING: USE EXTREME CAUTION WITH THESE WOOFERS! THEY PUT OUT A TREMENDOUS AMOUNT OF SOUND PRESSURE AND CAN DAMAGE YOUR HEARING!
Old Oct 15, 2002
mohawkboom's Avatar
it's overrated junk....the might put out 300Wrms x2..but the power will not be very clean
Old Oct 15, 2002
Nuts's Avatar
i need to find a good sub set up for the best bang for hte buck. nothing to expensive, nothing to crappy.
Old Oct 15, 2002
mohawkboom's Avatar
a US Acoustics800D and a pair of Cerwin Vega HED's or Memphis Powerbass subs... Inexpensive but good.
Check sounddomain.com for the amp
and onlinecarstereo.com for the subs
Old Oct 15, 2002
Nuts's Avatar
what about the infinity reference 10" subs. they're sellin on ebay for like 70 bucks a pair. i'm a noooob when it comes to I.C.E so sorry about the stupid questions.
Old Oct 15, 2002
mohawkboom's Avatar
the reference subs aren't as good as the HED's or memphis subs,,,the green cone Ininity Kappa's are though,,but are a touch more pricey
GolNat
Nov 27, 2018 03:32 PM
UltraHDGames
Jun 8, 2016 05:16 PM
General DIY
Sep 25, 2015 08:02 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
redcloud
Sep 7, 2015 01:45 PM
