Whats that sound coming from?
Old Oct 15, 2002
dru106's Avatar
ThE CoRRupToR
Hey guys! Im new here and i have a 2002 civic LX sedan. There is a little buzzing sound coming from the altenator and i have a kenwood HU, 420 ampifier 2 ch that powers 2 subs. Me as being an everyday driver how long do you guys think the altenator (probably bout 40 min a day) will last before it dies out? Is there a company out there that makes a better altenator? And is it worth getting an OPTIMA battery? Thanks!
Old Oct 15, 2002
mohawkboom's Avatar
it's not the battery or the alternator...it's your wiring....you most likely ran your RCA's right under the fusebox on the drivers side...this will add that noise...or your RCA and power wire are very close to each other at some point,,
Old Oct 15, 2002
Regularjoe's Avatar
Regularjoe is on a distinguished road
And check your grounds, make sure they are 100%.
Sand, scrape, file, and get the best connection possible.
I went through this saturday night. Got some new components put in. The installer re-arranged some things and moved the amp board. Bad hum all of a sudden. Claimed it was my older dammaged RCA's. I was like it didn't do it before and my RCA's are 2 year old Moster Cables. I knew they were fine.
I went home pissed. Resanded my ground (they had relocated it) and double shielded the RCA's anytime it got near anything with power and from where it pokes out of the back seat all the way to the amp in the trunk.
Now even between cd tracks, full volume, and revin the engine I get NO more engine noise at all.
Old Oct 15, 2002
LudlamTheory's Avatar
i boogie for the raindrops
how do ya double shield an rca cable?
Old Oct 15, 2002
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
tin foil
Old Oct 15, 2002
Regularjoe's Avatar
First I used a heavy duty spiral plastic wrap. More for bundling cables together. After that I covered it with split loom wrap. So my RCAs got huge, ended up bigger round than my thumb, but it was worth it in the end.
danace99
23
Jun 28, 2015 08:49 AM
werdnahall
May 17, 2015 11:37 AM
dennis123
May 3, 2015 03:14 PM
eX2ooo
Oct 5, 2001 12:19 AM
ernhole1
Aug 2, 2001 11:12 PM
