Speaker Clearance .......... Arah !!!!!!
Old Oct 8, 2002
Crashoveride's Avatar
Crashoveride is an unknown quantity at this point
Hey Guys
I am having a bit of trouble here and need some help on this.
I went and tore the hell out of the back of the car last night in an attempt to put my new Kenwood eXcelon KFC-X698 6x9's and they will not clear the springs. ( Link to the Specs on Crutchfield ) . So in the end I put my Sony Xplod's back in and put it all together again.
I cant remember if anyone else had this problem or not, and what they did to fix it. I know I can put gas shocks in there but i am not sure I want to attempt that, I called Honda to see if I could upgrade to the Heavy Duty trunk springs cause I wasnt sure if I read they will give me the clearance or not, and they said it wouldnt.
I guess in the end I am wondering if I need some spacers or not and if so what size will I need for this?, cause I tried a few things last night and they didnt look like they would let me put the rear deck back in.
Please help me guys, I really want to get these in there cause they would finish off my Excelon system in the car.
Thanks in Advance.
Crashoveride
Image of speakers --------------------------------->
Old Oct 8, 2002
Bellz's Avatar
I was looking at Crutchfield's chart in their catalog and found the Mounting Depth specs for you.
The car has 3 and 7/16" depth, and your Kenwoods have 3 and 5/16", so you have 2/16 or 1/8" clearance to work with. This ain't much, but it could work, theoretically.[IMG]i/expressions/face-icon-small-wink.gif[/IMG] But you said it wouldn't clear the springs. So much for the 1/8" theory.
Here's the real kicker though. The top mounting height is 7/16" height for the car, and 15/16" for the speaker. Therefore, you have a speaker that is 8/16 or 1/2" too high for the rear deck. This would keep you from getting the rear deck back on, unless you wanted to cut it up.
You're trying to force a speaker that is both too deep and too high for the car. Unless you want to mod the car to MAKE it fit, I'd suggest another set of speakers that have smaller dimensions.
If you plug in our cars specs, Crutchfield will give you a list of what is an Easy-Fit. It shows the Bazooka M690, Infinity Kappa 692.5i, and the Kicker 02K69 in the 6x9 size. If you look in the 6x5" size, you have 10 choices. I put some 6.5"s in there just for rear fill, since they fit easily and I'm using a sub for bass. If you're planning on getting a sub, getting some 6.5s makes more sense, and it'll save you from pulling your hair out shoehorning those exclons in there.
Old Oct 9, 2002
Thanks man, I am going to do some playing around on the weekend and see what I can do th make this work, a buddy of mine is really good with this stuff so he might be able to figure something out. Right now I have a Kenwood Excelon MP3 deck, Excelon 5 1/4's with tweets, the 6x9's (damm), and Excelon Subs. So I should have a good system all around but I want to keep it all Kenwood Excelon, so I might have to change what I put in the rear without doing some spring reworking.
Thanks
Later
Crashoveride
Old Oct 12, 2002
slick's Avatar
that little dude
slick will become famous soon enoughslick will become famous soon enough
Quote
[hr]Originally posted by: Crashoveride
Thanks
Later
Crashoveride[hr]
i can understand you wanting to keep the theme, but if its gonna be hard to do ( which is what it looks like ) i would give back the 6x9's if you can, or sell them, and get some excelon 6.5's, i'm pretty sure a 6.5 will clear the bar in the rear. i got a good deal on 6.5 boston acoustic rx67's from a friend ( 2 pairs for $50 a pair ) i went to home depot and bought a 2x4 sheet of 1/4 inch mdf, used the old 6x9 speaker as a guide, and cut out a 6x9 to 6.5 adapter, so now my 6.5 fits in the 6x9 opening. it was easy to do, and believe me, i have never done anything like this before. just an idea, but in any case, keep me posted on what you do, if you get those 6x9's in there, i will be curious to know how you did it [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Oct 12, 2002
Bellz's Avatar
Yeah, thats what I want to do with my 6.5"s in the rear. They're mounted in there pretty crappily now with a plastic adapter.[IMG]i/expressions/face-icon-small-frown.gif[/IMG] I gotta remember to go by Lowe's tomorrow and find something to use as a plate like you're doing. Then it's just a matter of finding the time to take out the rear deck to put them in. I plan on sound-proofing it though, along with the rear quarter panel areas and possibly below the rear seat. Somebody online once told me about some cheap material that Lowe's and Home Depot sells that's very similar to Dynamat. It's called Peal and Seal, and it's used as roofing material insulation. It has a aluminum-looking silvery side and has a peel off sticky side with some asphalt type material sandwiched in between. It's cheap and works great. It comes in 25ft x 6" rolls for about $12 per roll. I've already used it behind my door panels. It's much cheaper than Dynamat and works the same or better.
Check this link for product info.
Old Oct 13, 2002
slick's Avatar
that little dude
Quote
[hr]Originally posted by: Bellz
Check this link for product info.[hr]
hey, thats pretty clever, i'm gonna check that stuff out, i mean, $12 for a 25ft x 6" roll is damn cheap. i plan on getting a sub, so i can plan ahead with the sound proofing from now.
Old Oct 13, 2002
Hey Thanks slick. I might have to look into doing that, if not I was talking to a friend who is real handy with cars and he said he would help me remove the trunk springs and put in a gas shock. But I might just look into a 6.5 setup as well.
Thanks guys
Crashoveride
P.S. - That Peal and Seal is waterproof as well .........
Old Oct 21, 2002
RainRacer's Avatar
RainRacer is an unknown quantity at this point
Let me tell you I have always been a Crutchfield fan until recently. I oredered Kicker 6x9 which is one of 3 speakers that fit in the rear of a coupe. Wrong. Way to deep. They hit the truck torsion bars. So now I have Kicker 6-1/2 with an adapter.
I am not all happy with these speaker. They are rated to high for the stock system and do not sound good. I am looking into Alpines that are power matched to the Civic EX's stock wattage (30). Come in 6-1/2 and 6x9 but figure I'll have to do the 6-1/2s all the way around. I am looking for tight bass not ground pounding bass.
Are these good speakers? With a stock stereo? Any suggestions?
Link to Alpines
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
Mad Dog Tannen
Oct 19, 2016 08:12 PM
UltraHDGames
Jun 8, 2016 05:16 PM
Gsxtacy
Sep 12, 2015 01:09 AM
redcloud
Sep 7, 2015 01:45 PM
