stock speakers
Old Oct 5, 2002
Nuts's Avatar
Nuts is an unknown quantity at this point
stock speakers
well i want to replace my stock speakers in hte front and back. whats the best size to get that will fit easlily and whats the best sounding speakers? will the kappas fit?
Product ID: 62.1i Category: Speakers
Infinity Kappa 62.1i 6-1/2" 3-way Speaker
Description: With more than twenty years of experience and innovation behind them, Infinity's next-generation Kappa loudspeakers take technology to the next level. Each Kappa Series speaker delivers high-efficiency, long-term reliability and Infinity's award-winning sonic signature.
Key Features
6-1/2" Oversized C.M.M.D woofer
Impedance: 4 ohms
Peak Power handling: 140W
RMS power handling: 70W
Frequency Response: 50Hz-20kHz
Sensitivity: 89dB @2.83V, 1watt
Mounting Depth: 2-9/16"
Availability=
Price per pair.
Our Price: $99.00
would these be good for all 4 speaker slots?
Old Oct 5, 2002
Cyko's Avatar
Cyko is an unknown quantity at this point
1st off do you have a coupe or a sedan?
coupe:
front - 6.5
rear - 6x9
sedan: 6.5 all around
2ndly I would recommend getting components for the front..... better sound quality and better sound quality is good [IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
If you have a coupe you can't use those in the rear so get some 6x9's. If you have a sedan those would be pretty good for yer rear deck
Old Oct 5, 2002
Cyko's Avatar
oh forgot to mention, they should fit if ya get some spacers
Old Oct 6, 2002
Nuts's Avatar
yeh i have the coupe. are those good speakers. i'm a I.C.E. noooooooooob
Old Oct 6, 2002
Borgus's Avatar
Borgus is an unknown quantity at this point
Those 6.5inch Kappas are good speakers. I had them in my old celica. However, I would probably go with some sort of component set (replaces the tweeters and the mids) because in general they will sound better, and the stock tweeters are not up to standard. How about the Infinity Reference component set? It sounds like it would be in your price range, and, in my opinion, would give you a better sound by balancing out your sound stage (as opposed to just replacing the mids in your doors). I dont think I would want to replace the door speakers to have sound quality taken away by the awfull tweeters in your A-pillars. Get a component set and replace them both. It sounds like you want the best bang for your buck, so I would definitly reccommend the Infinity Reference Component set.
As for the rear speakers. These are 6x9 inches, and you will want to replace them with a coresponding size speaker. You dont have to go all out here because rear speakers are primarily just to provide fill in the rear portion of the cabin; the components up front will be doing 85% of the job. So, I think it would be a nice match to get the Infinity Reference 6x9s in the rear. They have angled tweeters within the cone, and will allow you to pivot them towards the front of your car.....allowing for better imaging (hence, better sound). You will not be dissappointed in the reference line up.
Conclusion: Infinity Reference 6.5in for the front.
Infinity Reference 6x9in for the rear.
Spacers to make them fit (probably no more than 3/4 in)
Additional Note: Ebay is the cheapest place to get your audio stuff. Can easily save hundreds of dollars. Enjoy your sound!
P.S. I am not an Infinity salesman because my car has a mixture of brands in it [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Oct 6, 2002
Nuts's Avatar
thanks a lot man. cleared everything up for me. i think thats the set i'm gonna go with. and when i get that i'm gonna 2 10"s to complete the system.
Old Oct 6, 2002
Nuts's Avatar
oh yeh, whats the best amp i should use? how many watts and channels. a memphis 600 watt amp was reccommended.
Old Oct 6, 2002
SQCivicEX's Avatar
SQCivicEX is an unknown quantity at this point
Since you mentioned Memphis, I'd suggest the Memphis Belle. You have 75x4 for your front stage and rear fill and 300x1 for the 2 10" subs you mentioned. The JL 500/5 is also an excellent choice. Otherwise, a nice 4-channel and class D amp should do you just fine.
Have fun!
Old Oct 6, 2002
Borgus's Avatar
Hrmm. Make sure you have a different head unit because you will need one with at least one set of pre amp outputs to add an additional amplifier.
However, assuming you do in fact have a aftermarket CD player with a set of pre amp outputs, I would go with a 6 channel amp. Kicker makes quality amps, but it is mostly personal preference. The reason I suggest 6 channels is because you will want 4 channels for your speakers (2 for the front and 2 for the rear). Then, since you mentioned having 2 10in subs.....you could use the extra 2 channels to power each sub. It would make a nice clean install, not having amps scattered everywhere. Try looking for something close to 50x4 +200x2......that would produce an excellent sound quality system. Good mids, highs, and bass....
Just my opinions of course. Need anything else, just ask.
(p.s. if money is tight dont forget to factor in installation accessories such as speaker wire and an amp kit)
Old Oct 7, 2002
JohnDoe's Avatar
JohnDoe is an unknown quantity at this point
PPI.. I can't remember the model though.. It's about the size of a surfboard [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Misfit2613
Jul 30, 2015 09:49 AM
Nalmonte
Jul 22, 2015 09:08 AM
NoobyKid
Jul 13, 2015 07:53 AM
7thgensurvivor
Jul 5, 2015 12:17 PM
