alpine type r 12" sub
A "600W Class A/B amp" or "300W Class D amp" would be sufficient for this sub(i am going by the max ratings of wattage for these amps). I am just trying to recommend powering this sub at least at it's RMS wattage rating.
The 300w rms in the thermal power handling. The mechanical power handling of the sub is dependant upon enclosure type and size. I had my 10" type-r in a sealed enclousure with a low Q, and could push it to its limits with 250w rms.
By the way, the class of the amp does not make a difference. If it is a class AB amp rated at 300w, it will put out the exact same power as a class D amp rated at 300w. The class D is just more efficient and will be less strain on your alt.
I personally would only throw 300w at that sub in a sealed enclosure with a low Q. You will have excellent SQ, while getting decently loud. If you put more power to it, you should go with a smaller enclosure, but it will be more boomy and loose transient response. If you know what you are doing and know how to properly set your amps so that you will not clip the signal, then you will be fine with 500w, just make sure you turn it down when you are reaching/exceeding the mechanical limits...
The type r's are definatly tight. I'm getting stupid this spring and build 2 15's into the trunk in a fiberglass enclosure.
Don't be afraid to give a sub too much power tho. Most subs are blown from lack of power because of distortion and not from overpowering. In the alpine rsx they are running 1000 watts rms to each one of the subs which are only rated at 400 watts rms.
thats actually a common misconception, you can never "blow" a speaker (thermally) due to too little power... otherwise you would blow your speakers/subs every time you had the volume low.
When underpowered, people blow drivers from the clipped signal if the driver can't handle the increase in power. I overpower all my drivers but I know what I am doing. I definately don't suggest for people to overpower there speakers unless they know what they are doing and have everything setup properly, and know when to turn it down. Also, the power handling of a driver is dependant upon enclosure size and type. My Shivas are rated at 600w rms each, but with a JL 500/1 amp on the pair (250w rms each), I can push the subs to there mechanical limits in a sealed enclosure with a Q of .707 without any bass boost on the HU or amp.
Quote
[hr]Originally posted by: MangoEX
thats actually a common misconception, you can never "blow" a speaker (thermally) due to too little power... otherwise you would blow your speakers/subs every time you had the volume low.[hr]
-Mystic
The LA Clipper
Quote
[hr][i]My Shivas are rated at 600w rms each, but with a JL 500/1 amp on the pair (250w rms each), I can push the subs to there mechanical limits in a sealed enclosure with a Q of .707 without any bass boost on the HU or amp.[hr]
I haven't got the chance to build the enclosure yet since I just received the subs last week and the weather is horrible, but they will be placed in seperate chambers of 2ft^3 each (4ft^3 total) with about 2lbs. of poly fill per chamber. I am going for SQ, so they require a large enclosure to achieve the low Q I like. When I plotted them out, on average, the pair will be 10db's louder than my previous 10" Brahma with the 500w from my JL 500/1.
By the way, I am selling one of the Shiva's if anyone is interested, since I am only using 2 of the 3. Email me at faintreality@hotmail.com or PM me if interested. I posted at www.clubrsx.com , but will probably post here a lilttle later tonight in the for sale section.
The LA Clipper
Are you gonna go to the South Clai meet on the 4th...I would like to check out your ride for sure...I know the others would be interested in seeing an RSX there
I have my four in 1.4 cubic feet per, with 1.5 pounds of poly per chamber. I have 300 watts going to each from a JBL 1200.1. It is WAY to much bass...I have it turned down 7 decibles and it is still a lot of bass...anywayz, sometimes I like to boom
Exactly Mystic! Thats what I was trying to say.
I have been installing now for almost 8 years and about 95% of the subs that come back blown are from distortion and not from overpowering.
You got 4? The 2 will be way more than enough for me... You got any pics? I have no clue if I will be able to make it to the meet or not, I still haven't made it to and RSX meet, and they have one like once a month.
Dave
Dave
Quote
[hr]Originally posted by: fonto
[hr]
[hr]
The LA Clipper
Quote
[hr]Originally posted by: FaintReality
Dave
[hr]
Dave
Quote
[hr]
[hr]
Yeah, I have 4 and it is a little too much, three whould have been enough. My set-up is nothing special, two prefab boxes facing up...and of coarse I have no truck space. I did it all myself, and it was my first time...so it isn't going to wow anyone, except for the SPL
Touge
Sep 23, 2015 10:51 PM
